1999 150k miles five speed clutch making noise help!
Hi there everyone. I got what sounds like a tin can rattling around in the bellhousing area. When I push clutch in it goes away and today it started making noise when you release the clutch slowly kinda a sqeeling. Is this the Throwout bearing you think? If so how hard of a job is it and how much for new throwout bearing? All aspects of the trans are perfect no clutch slipping, shifts great and easy. Thanks CD
Sounds like bearing, clutch cover, clutch disc, or bearing support broken. These failure are self evident upon separating the transmissin from the engine.
Upon inspection a decision if you want to put it back together without completelly replacing the disc, cover and bearing. With the milage I'm sure all components are showing wear.
Some one chime in here please tell me how much and what I should go with. Future plans include programmer, muffler, air filter and leave it alone. thanks CD
Johnmesich
16
06-22-2012 08:36 PM
Justwannabeme
03-03-2011 11:27 PM
04600CTDRAM2500
02-21-2010 09:23 AM
Chris Derrick
01-13-2010 03:46 PM
