1998/2001 rear end gears
It depends on the transmission that is in the truck. If the truck has a manual transmission then the rear end will be the Dana 80. If the tranny is an auto, then the rear end is a Dana 70. You can interchange the 80s with each other, and the 70s with each other, but you can not change use a Dana 80 carrier and gearset in a Dana 70 housing or vice versa.
Thanks. Both are/were auto tranny's. He swapped out 3:77's for 4:11's after about 40K miles. He has since sold the truck but has the gears and will give them to me for a case of beer. Then all I have is the labor to swap my 3:54's for the 3:77's.
You can get Dana 3.73 gears, but just not in our application from OEM. Not sure switcing from a 3.73 to a 4.10 set would be worth it, or a 3.54 for a 3.73. Thats a 5% change in final drive ratio.
1998 12vavle
06-01-2014 08:36 PM
doorguy
06-08-2007 06:19 AM
badmrb
05-27-2005 05:48 PM
