1693 Blues
Old 10-02-2003 | 11:18 AM
jec3's Avatar
1693 Blues
For the last month my truck has been throwing a 1693 code constantly. No other codes come up. I know this is a nothing code and the truck runs fine but I have a contant CCD on my overhead computer. I've had an EZ installed for about 9 months now and am wondering if the EZ is causing the code, again runs fine but could EZ be going bad? I've read where others get codes from their boxes. I just want to be able to read the outside temp on my overhead computer but can't with the constant CCD display.
Any suggestions?
Old 10-02-2003 | 02:38 PM
DODGE4X4's Avatar
Re:1693 Blues
My Power Puck threw codes out every now and again. What I did (as per advice from this site) was put Dielectical silicon on my connections. That took care of it for me it might solve you problem
Old 10-02-2003 | 04:03 PM
Timinva's Avatar
DTR Advertiser
Re:1693 Blues
Have you hooked up a scan tool? On 00 trucks it will show p code 1693 when you do the key check but show other codes with a scanner. Mine showed a 1693 stored without the check engine light but with scan tool it showed p-251,252. Tim
Old 10-06-2003 | 11:34 AM
jec3's Avatar
Re:1693 Blues
Thanks for the replies, I'll check into both suggestions...
Richard1234
10-02-2003 10:28 PM
Rayzor
07-12-2003 11:55 PM
cortez
04-07-2003 04:35 PM
jec3
03-20-2003 10:39 AM
BOB
12-14-2002 08:20 PM
