0216 at 68K miles
0216 at 68K miles
On Thursday, I had believe I had the dead petal syndrome. I'd goose it, with nothing happening. It had zero power and seemed to stumble a bit. I had a 130 mile hihgway drive, and the mileage was a bit less than normal. On Friday, I ran the AC. It felt like the AC was actually taxing the motor. It's FLAT, no zip at all.
Friday night, ran the codes. 0216.
I have an aftermarket warranty, so I'm hoping to have the IP and LP replaced underwarranty. The truck is also under 5 years old and only has 68K miles. Would the Cummins warranty cover it also? I might have a better service going through them. It will be done at a dealership.
Am I going down the right path? Does this really fit the bill for an early diagnosis of a dead vp44 and lp? I know others are running for a long time with the code, but I'm towing 1400 miles at the end of the month.
02HO, QC 4x4, NV5600. Bone stock.
Do a search here as I think I just read that the thing is warranty for 8 yrs 100,000 something,
I'll search for the thread...
Found it....
http://www.turbodieselregister.com/f...-you-ride.html
Found it....
Let us know what your fuel pressure is.
HTHs,
Joe
Unless they changed something between 99 and 02.... you could very well still be under warranty.
Run to the dealer. Your 5 year/100K warranty should cover that as long as you bought the truck a little later than this time of year.
I know the 03's were starting to hit dealer lots in late July. I had one ordered in May and it was one of the first in our area.
Those symtoms and the death code.... IP DOA Get it in to the dealer before your trip. They will probably change out your LP to an in the tank model too in order to warrentee the IP. Don't ask me how I know this.
Another update: I ran it last night for about an hour to get home. It seemed to run fine, but flat. And then...at 70mph on I-95 south of Baltimore...nothing. 15 seconds of butt puckering dead pedal. Outside temp was about 75-80.
Ran the same distance this morning @ 65mph. No dead petal at all. 40 degree temps.
OK....
Hopefully they will replace the LP and IP for you. Make sure you insist on replacing the LP too. Some dealers etc. will think they just need to replace the VP-44 since the code just points to the injector pump.
Then, make sure you get a FP gauge on it. A FP gauge is critical equipment on a second gen 24V. If you need help with the FP guage, just ask...
Good Luck.
Good Luck.
OK....
Good Luck.
Good Luck.
I talked to my warranty company. They will only cover the VP44 if it's bad. No luck on the LP, and they will NOT cover the VP44 if the LP took it out. :rollseyes:
They will provide X number of dollars for the VP44. They may ask for a reman be used. What are the drawbacks of this? If I could upgrade to a new one (at my cost), would it be worth it? What about going all the way to a HRVP44?
I believe they are all remans, I don't think Bosch is manufacturing the VP44 anymore. But I'm not sure.
If you still have DC factory warranty, you need to go to a dealer ASAP. You will have 10X more hasseles trying o deal with an "aftermarket warranty" company. trust me, been there done that.
