02 dually 5 speed
02 dually 5 speed
Does anyone know if a bolt missing from the drivers side engine mount where it meets the block would give an oil leak, I just bought this truck and it is leaking from behind the stater and the only thing I see is a bolt missing from the mount. I recently did a 380 mile trip at 70 mph and used 34 gallons of diesel, is 11 to the gallon normal, or do I have a problem. Where the lift pump should be next to the filter is just an aluminum block with one pipe in and one pipe out. please help !!!!!!!!!!
I can't help you with your oil leak, but your gas mileage seems to be off. I have an 02 dually with a six speed and I am averaging 19 miles empty and about thirteen or fourteen pulling about twelve thousand pounds.
Sonny
02-15-2004 11:47 PM
