02 dodge blowing white smoke
Old 08-27-2014, 02:30 PM
BrandonH's Avatar
i have a 02 dodge 2500 5.9, i have just changed the vp and lift pump less then a month ago but the codes still show when i turn the key 3 times. recently i have had problems starting the truck like it wouldnt turn over all you would here is a click and that was it. had power to everything else so i tapped on the starter and it started. i have a new starter coming. now i also sometimes have a dead pedal for 10 seconds or so when first started and white smoke comes out when i hit the gas sometimes. nothing is done to the truck it is stock any help would be appreciated as im newer to diesels. thanks
Old 08-27-2014, 03:08 PM
BrandonH's Avatar
Also has the code p0230 I'm going to get the codes cleared and see if they come back. The lift pump is bypassed to the starter key I believe
Old 08-27-2014, 04:04 PM
BrandonH's Avatar
also yesterday the engine coolant was complete out so i put new stuff in there but it was a different color and different coolant that was in there before and so im assuming its mixed is that bad? and would that cause the white smoke cause it just started white smoking sense then
Old 08-27-2014, 04:12 PM
BrandonH's Avatar
the coolant that was in there is green and what i put in there is dex cool
Old 08-27-2014, 11:15 PM
roughstock's Avatar
If you're losing coolant and puffing white smoke, id say there is coolant getting into the cylinders. head gasket or head issue.
Id flush coolant and put in correct stuff. I don't believe DEX cool is meant for these engines.
Old 08-28-2014, 08:23 AM
patdaly's Avatar
Dex and green used to make cottage cheese in the cooling system.
I think you need to get this one professionally diagnosed, if it is losing coolant and white smoking, good chance of real damage.
Did it get hot?
Old 08-28-2014, 09:31 AM
SIXSLUG's Avatar
I agree with patdaly....
Your starter probably just needs a $6 set of contacts...get the heavy duty ones...
As for the white smoke, well a blown head gasket would be my first guess, however, I would be careful starting it after a while of sitting, you may have a cylinder full of antifreeze.
Trying to start in this condition will really get expensive.
Old 08-28-2014, 11:02 AM
BrandonH's Avatar
No its not getting hot and is running good it's not always white smoking. Thankh for the replys I'll be taking it to get looked at Saturday. Will a blown head gasket throw a code?
Old 08-28-2014, 06:45 PM
patdaly's Avatar
Nope, won't throw a code, do you know how or where you lost your coolant?
Any chance your water pump is leaking out the bottom?
Old 08-28-2014, 08:07 PM
BrandonH's Avatar
No I have no clue about the coolant there was coolant in the radiator but none in the clear tub thing. I haven't noticed any leaking but will look tomorrow. Would it be safe to drive or should I let it sit till taken to a shop. I opened the radiator and started the truck and it didn't bubble also oil is dark and looks good
Old 08-29-2014, 08:26 AM
patdaly's Avatar
I wouldn't go far without knowing what is going on. Around town is probably OK, just watch the coolant like a hawk.
For your code 0230........
http://articles.mopar1973man.com/2nd...t-out-of-range
Old 08-29-2014, 12:59 PM
BrandonH's Avatar
Well started it today to go to the store and had dead petal bad and white smoke just barley hitting the gas but after 5 minutes of running no white smoke and dead petal witch felt like hours was only a couple seconds. Have an appointment at 10 with dodge tomorrow. Isn't dead petal a sign of vp problems? This one isn't even 2 months old and pat thanks for the replies I greatly appreciate it
Old 08-29-2014, 06:38 PM
patdaly's Avatar
DP can be the pump, could be the APPS as well, could also be wiring.....
Old 08-29-2014, 11:13 PM
SIXSLUG's Avatar
Turbo boots in good shape?
A bad one/loose one can rob power and cause white smoke, weird its intermittent though...
The lower driver's side one on mine was getting cut by the sheetmetal back when I got my truck in 04.........
Old 08-30-2014, 02:09 PM
BrandonH's Avatar
I put some injector cleaner in the tank and it's nice black smoke now i had to drive ruffly 150 or so miles last night and didn't burn more fuel then normal and didn't loose any coolant maybe just bad fuel? Six lug I'm not 100% sure what the turbo boot is lol
Quick Reply: 02 dodge blowing white smoke
