02 Air Filter Minder
How do I get the filter minder out of the stock air box without breaking it? Do you just push the rubber seal back out the top? or does it open up and you can screw it out? thanks
I'd just leave it where it is, they are notorious for not working.
If you're changing to another intake system, you don't need it anyway, as you'll be able to visually see the filter getting dirty.
phox
phox
I've had stock air filters plug up with trash and the filter minder never moved for me...I even had it replaced by the dealer and to the day it's never moved. I've used a vacuum source to see if the minder actually does work. Really it does work but you need like 5-10 inches of vacuum to move it. By then it's to late your MPG is going south and the filter media with be distorted...
So I pulled the whole air box out and replace it with a BHAF... Never looking back... No more greasing the gasket, dirt leaking pass, fighting to open that foolish box, etc...
I know that i dont really need it, but the intake system has a hole pre-drilled in the box, if i dont install the filter minder in there ive gotta plug the hole with something that isnt going to fall out,get sucked in, or leak unfiltered air into the hose...
I held on to it, but I'm not sure why.
got it handled.... i was just worried about breaking the plastic, same with the nut/rubber grommet combo that holds the stock box on.... was being too gentle with them...
Quad box sounds and feels awsome!!!
89dieselkong
02-26-2013 05:02 PM
DennisT
16
08-31-2007 03:09 PM
royta
09-17-2005 10:25 PM
