01 4x4 ctd front hub removal
Do NOT use a puller, you might pull the bearing assembly apart. In short, you put the bolts back in, but leave them out a bunch ot threads. You place a socket one of them, and put the back side against the axle tube and then use the power steering to "push" the hub/bearing assembly out as you have your helper turn the wheel. Works like a charm and doesn't hurt the bearing assembly.
SilverRam3500
20
06-07-2007 07:27 PM
Crimedog
02-27-2007 10:39 PM
