01 3500 with spun rod bearing
I just purchased a 2001 3500 4 x 4 w/ 120k. Has spun rod bearing & motor is locked up. Is it cheaper to replace crankkit & Rod, or replace motor? Anyone know anyone in Indiana capable of repairing existing engine?
ck ebay there is a short block, this guy has one...COMPUTERS/PAIR Item number: 140071295009 i hhink it has 149000 just broke in
Do you know for sure that it has a bad bearing? If in fact it does the motor should be rebuilt. With all the crap from the bearings floating around it needs a complete tear down to repair it properly. If you were closer i could do it for you.
I just went thru a motor swap and bought a complete block with 130,000 miles on it for $3500 at a sacramento salvage yard. The motor swap was not easy however I was looking to have it rebuilt when I noticed the stamp 53 on it. The first thing I thought was get rid of the block.. Rebuilt is roughly 5500 with R and R. Good luck
Bobcat698
15
05-19-2010 04:50 PM
yoadriane007
12-13-2009 11:44 PM
Dodge2
12-20-2007 06:59 AM
