WTB: drivers window motor, tailgate bar
Hey guys, I'm needed a couple of items and would like to know where to get them.
I need the drivers side window motor, new or rebuilt. also needed is the scissor bar that supports the tailgate. Used is perfect, new is okay.
Last edited by wannadiesel; 04-23-2006 at 04:38 PM. Reason: ad removed, site rules violation
Originally Posted by keithplacervill
on the motor you might want to take it out if you have not sometimes the wire pops off just solder it back on good as new
that pretty common?
I just bought an '89 D350 today, and the passenger window doens't move...
driver's side power window works fine, but neither switch move the passenger window...
if it's not a wire, do I just replace the motor? there's not a fuse anywhere for just the one side, right?
Thanks.
Greg
Originally Posted by loch
Also if the indow moves but stops its the plastic gears, avalible from auto zone for 19 bucks plus motors are as well.
Yes, my motor runs the whole time, but the window starts and stops again. Till today, now it doesn't move at all, but I still hear the motor turning.
so I have to replace the plastic gear on the window motor, then? I thought it was metal? do you take the window motor apart to do this?
Originally Posted by BigWaylon
that pretty common?
Thanks.
Greg
Thanks.
Greg
That will let you know if you have a break in the wire somewhere. If you still don't hear the motor turn on, pull on each wire to see if they are loose or still connected. IF they are connected then you have a burned out motor.
Mine turns, just the window doesn't move.
tennman0258
10-03-2011 09:27 PM
Lightman
18
11-19-2003 05:15 PM
