Would you replace this spindle?
Front spindles on the dana 60- Both have a ridge at the bottom where the bearing has been riding. They measure out at 1.98-2.00 on the outer surface and 2.24-2.25 on the inner. Surprisingly, they don't measure out as egg shaped but with the ridge on the bottom, I assumed they must be? Supposedly, stock is 2.020 and 2.255. The bearings published inside diameters when new are 2.00 and 2.25 (who puts a 2.00 bearing on a 2.020 spindle?)
Anyway, with the ridge and mild scuffing, would you run these spindles?
290K on the truck/axle
Mine I just checked on after 5,000 miles were MUCH worse when I first did them 5,000 miles ago. I just didn't back off my wheel bearings a full 90* like the FSM says. I torqued to 90 ft-lb and only backed off 45* or so.
My 93 FSM says torque to 50 ft lb to seat bearings, back off, retorque to 31-39 ft lb while rotating disk, back off 135-150 degrees, then put washer on, then torque outer lock nut to 160-210 ft lb.
1st Generation Admin
I can't get around the thought that the wear shown indicates the inner race of the bearing has been spinning/moving on the spindle. They're not suppose to do that.
It seems to me that if run as is with a new bearing, the slop is gonna let things wonder and one way or another, allow early bearing/spindle failure.
If it were my mess, I'd replace the spindle. ($.02)
I would get a new and keep that for a spare. If I were to run it, I would check on it more frequently.
The bearing races actually walk/creep on the spindle, so the load/wear from the weight of the truck gets cycled around the race over time. Loctite in this area isn't a good idea.
***** punch top bottom, side to side (4 times) or side to side (2 times) where each bearing sits it'll be harder to get the hub on but it'll hold those bearings....
I've seen the result of people using loctite on pinion races to stop them from spinning, haven't seen it work yet! On something as vital as a wheel bearing, the only way to fix it is the right way, replace it! Just my opinion
RoadDiesel
08-02-2011 11:27 PM
ctd4stan
06-05-2008 06:34 AM
jrsavoie
01-19-2008 10:55 PM
tthomass
20
08-19-2005 09:35 PM
