Won't Idle, Hard Starting When Hot
Lately my truck has developed a starting problem after warming up: it takes a lot of cranking & more pressure on the pedal to start. Yesterday it stalled as I stopped after exiting the interstate, and would not start or idle without my maintaining pressure on the go pedal. Stalled a couple of times again last night. Each time the engine was fully warmed. The fuel filter is 2-3000 miles old. Is this a lift pump problem? It just seems like it fuel starves, but I can't think why it would only happen when the engine is warm. It does run fine until I let off the throttle-- then sometimes it dies. This has me very concerned, because I'm an insurance claims adjuster, hurricane season is here, and I'm going to need this truck soon at a moments notice. Any and all help greatly appreciated.
- Chris
- Chris
Change your filter. Then, make sure the fuel lines are in good shape, maybe they allow some air to get in after they heat up. Have you had to blead the injectors at all to start it? The lines don't have to be wet from fuel to be bad. Next I'd check the condition of the lift pump, then then pull the shut down solonoid and check for crud in there. At least you'll have the cheap fixes worked out before you spend money on an injector pump.
I second the air leak diagnosis - which could be the lift pump. '92 and '93 trucks rarely have trouble with the lines, but yours sounds like it's sucking air.
hopefully not this problem
http://www.turbodieselregister.com/f...2&goto=newpost
Thanks very much to everyone for the helpful advice!
-Chris
Strjock81
16
12-12-2007 09:53 AM
abc4yew
03-15-2007 11:55 PM
duallydave
08-07-2005 09:38 PM
