Wiring Info needed
I was talking to Jim Lane about doing my headlight relays last night. This morning early my switch went out along with the plug. The plug is a melted mess. Now I need to find a good plug somewhere. I said many bad words trying to get the switch out. Good luck on your switch.
RollingCoal, my plug was also melted, and I couldnt find a replacement at all, so I used weather-tight crimp-on disconnects and have several of the wires "plugged" in individualy. I left the remains of the plastic "plug" in place to help isolate and ID where they went. it works just fine.
The trick to getting the switch in/out easier is to depress the parking brake as far as you can and reach up between the sidewall and the hood release.
It is hard to believe that Dodge used such light wire to wire a truck that is used to pull trailers ect.. I am either going to wire it all into a set of toggle switches or find a switch and plug out of something else and try to figure out the wiring scheme. Then put it all on relays and be done with it. I love my ole Dodge but the wiring is a pain, throughout the whole truck the wiring lacks alot.
wyododge
01-13-2009 02:25 AM
charcoal600
04-30-2005 02:34 PM
