Wiring harness
Wiring harness
I'm putting a visor with clearance lights on my truck before it goes for paint at the end of June, but my question is does anyone know where the wire is taped up in our harness if the truck wasn't equipped with lights? I'd like to keep it simple by using the original wires instead of using new wiring and adding to the little bit of wiring we already have. Thanks
Take a look here: https://www.dieseltruckresource.com/...0-t267173.html
As for the harness that goes up the A-pillar it wont be there since your truck wasnt equiped. But the pigtail from the main harness is usually found taped to the door switch wire. If your under the driver dash look at the wires that go threw the large hole right under the A-pillar. I normally find it there! I have installed 3 sets of these lights and its either taped (to the door switch wire) in the hole, or simply hanging at thata hole. Good luck
wyododge
01-13-2009 02:25 AM
Hummin Cummins
03-24-2003 07:41 AM
