Window and Door seal kits....
Thought I'd update with some part numbers for these door kits. I just spent the last couple hours researching the crap out of these. I found everything on Rockauto, and then was able to find it through E-bay as well.
So depending on how you like to spend your money you can choose either. I like E-bay because if I buy through the airmiles site, I get free airmiles with my on-line purchase.
Anyway here is the numbers I found...All kits, and products, are produced by Fairchild Ind....
Complete kit that services both LH and RH doors....You get everything including door seals...
-Rockauto...KD100210A
-Ebay...KD1002-10A
Complete LH and RH window seal kit...less door seals...
-Ebay...KD1001A
And the 4 piece glass seal kit for LH and RH doors...
Rockauto...KD2003
Ebay...KD2003
The E-bay kits I bought came through the JC Whitney E-bay store. So you could probably use those numbers on the JC Whitney website to come up with the same products. If you prefer to buy through them.
Anyway these kits work for all Dodge Rams, Ramchargers, and Traildusters from 80-93. Hope this helps others out.
-Ebay...KD1002-10A
-Ebay...KD1001A
Rockauto...KD2003
Ebay...KD2003
I ordered the kit from RockAuto. Hope to get it installed, along with my new window motors, this weekend. Its a complete kit from waht I can tell. I plan on using the write-up in the sticky to install everything.
Weather stripping install:
https://www.dieseltruckresource.com/...d.php?t=152939
I bought the Rockauto kit for the doors and the vent window seal from E-bay, all fit beautifully and between the two, it was everything needed...Mark
Received 1,648 Likes
I Bought those as well.
They do fit, but they need "trimming" as they're a little different. The bottom has a little that needed to be removed, and the upper glass attachment doesn't go through as the original one did, but wraps around. Although they went in fine, the window still doesn't seal completely at the lower front portion of the seal. Disappointed, but it was better than the original ones that were hard as a rock.
BTW... ordered the "door seal" only from RA, as I already had the others. I'm speaking of the seal that mounts to the cab that the door closes on, as they're the only ones that I haven't changed yet, otherwise the entire cab has new seals.
RA was 1/2 the price of the ebay ones... Both made by fairchild.
I had ordered the complete kit a few years ago for my front and rear doors on the crewcab. I didn't keep all the part numbers, so I had to find them all over again. And the info I found on the DTR was not much help either. That is why I posted up the part numbers.
I didn't need new door seals, so I just ordered a few pieces to redo the 93 doors, and re-do the sweeps on the rear crewcab doors.
moneytlks01
06-30-2011 04:51 PM
Igor
08-06-2007 09:39 AM
ed cloud
01-13-2005 10:07 PM
