will any 12v injectors work?
nope. We're limited to Bosch 185's, Bosch 190's and PODs. And cu$tom EDM's. Go PODs if you play, 190's if you tow or EDM's if you've got way more $$$ than me
Most any vendor on this site will be able to get them. Piers up in Canada seems to have a strong 1st gen following---check out their website in the links section. Judging by the level of crust under my hood, I'm guessing my stuff's all factory
My understanding is that with the POD's you have to make sure to get the right thickness of copper washer. Piers Diesel Inc. will be able to supply you with the right stuff plus they will give you good advice.
EDM's are the way to go if you can afford them, you get more atomization which translate to more fuel being burnt and that means power, but they dont smoke as bad as pods do, its a terrible draw back to fuel being atomized. But if im not mistaken a sec gen head will fit on our trucks, if so our nozzle options are a lot better.
Someone correct me if im wrong on the head fitting.
An injector shop can build you custom injectors with 2nd gen nozzles and 1st gen bodies. POD's flow more than 370's, so there's not much point to it though.
snowmanx
05-23-2010 09:18 PM
CTD2001
09-29-2008 10:57 AM
