Will A 14cm Non-WG Housing Bolt-Up?
Old 06-17-2006, 07:03 PM
jrussell's Avatar
I am getting a 14cm non-wg housing and want to have everything needed for the install when it arrives. I know I have to move the exhaust about 1" back, but other than that will this unit bolt right up?
Old 06-17-2006, 08:03 PM
Yes, it will fit like it grew there. Get a new flange gasket and oil return gasket, they are around $5 at Dodge for both. Just lie to 'em and tell 'em it's for an '02.
Old 06-17-2006, 08:14 PM
G1625S's Avatar
The non-WG housing won't require you to move the downpipe back, fwiw.
Old 06-17-2006, 08:17 PM
Sorry to disagree with you there, Greg, but the non gated 12's and 14's are made off the same castings as their 'gated brethren - they just don't have the passage drilled or mechanisms installed. They take up just as much space and the exhaust still needs to be moved.
Old 06-17-2006, 08:19 PM
G1625S's Avatar
Thanks for the correction Dave...ok, I learned something today, can I go back to slackin' now?
Old 06-17-2006, 08:24 PM
Nope, I'm getting ready to go to bed. You gotta stay here all night and answer questions.
Old 06-17-2006, 08:26 PM
G1625S's Avatar
Oh very well then Lets Git 'er done
Old 06-17-2006, 09:11 PM
jrussell's Avatar
Sweet, thanks for the answers guys.
Your post above got me thinking (and that can be dangerous for all involved ), if the casting is there can one just drill the hole and drill/tap for a wastegate/boost controller like most of you guys are running?
Come on, lay it on me...I know if can't be that easy!
Old 06-18-2006, 04:04 PM
frostie's Avatar
When Im going to change an exhaust housing. I just loosen the oil drain clamp down on the hose and pull the drain tube with the turbo. I guess im a bit lazy, I hate to scrape that drain gasket, it can be a pain.
Old 06-18-2006, 04:09 PM
flashgordon's Avatar
I'm curious to! Has any one converted a non waste gate 14-12 to a waste gate? is there part available to do this?
Old 06-18-2006, 04:15 PM
jrussell's Avatar
I have yet to see a WG housing close-up in person, but it seems if they are from the same casting and a boost controller takes the place of a stock WG, it should be possible.
Are there some internal parts on a WG housing that would be needed to convert a non-WG housing over?
Old 06-18-2006, 06:21 PM
Yes, there's a shaft and a flapper inside. It could be done pretty easily by someone competent with a milling machine.
Old 06-18-2006, 06:49 PM
So you could just drill a hole were the flaper valve sets?
Every thing els is there?
Old 06-18-2006, 07:05 PM
jrussell's Avatar
Also, does a boost controller replace that stock wastegate/flapper, or are those two different components?
Old 06-19-2006, 12:10 AM
edwinsmith's Avatar
Received 1,048 Likes on 770 Posts
AFAIK the housings are totally different in the area necessary for the WG valve. There is an added cover with 5 bolts that covers the WG hole and the ducting back to the exhaust port. The cover also has the flange for the downpipe or in later models an angle turndown that clamps to the downpipe.
It would take more work than it's worth to convert a NON-WG housing into a WG housing and it probably wouldn't last long because of the heat.
Edwin
Quick Reply: Will A 14cm Non-WG Housing Bolt-Up?
