WIF Light
Old 02-23-2010 | 03:08 PM
PADuallyBoy's Avatar
WIF Light
My light is on and is staying on even after I removed the filter and drained it entire and refilled it with fresh fuel. Any idea why?
Old 02-23-2010 | 03:22 PM
larrybartlett's Avatar
although mine is a 2nd gen you have a short somewhere, mine comes on everytime I wash under my truck, then goes off
I just haven't taken the time to fix the short
Old 02-23-2010 | 03:59 PM
rebel_horseman's Avatar
Muted User
The WIF sensor is likely the culprit. If it gets moisture in the connection it will cause a connection making the light come on and it will take a while for it to dry out enough to work right. You can get a new one for about $20 from Geno's Garage. Mine did the same thing and I left it unplugged for a few months. Decided to plug it back in and try it and it worked fine.
Old 02-23-2010 | 04:04 PM
Okay, I'll go that route of leaving it unplugged. I'm sure it's just a moisture issue. Thanks guys.
Old 02-23-2010 | 05:33 PM
schamran's Avatar
Mine turns on every time i go through the car wash. funny part is I don't have a sensor anymore. I use a filter with a drain in it.
Old 02-23-2010 | 05:41 PM
dzl_damon's Avatar
Blast out the sensor with some WD40 then some electi-clean. The WD will drive out moisture. I've heard this works.
Old 02-24-2010 | 07:10 AM
rjz5400's Avatar
also there could actually be water in your fuel. suspended water may go past the fuel filter, even an aqua block filter...
Old 02-24-2010 | 08:15 AM
ZSkibo's Avatar
What you most likely did was screw the WIF sensor into your filter too tightly. It causes the tip of the sensor to contact the base of the filter, shorting the circuit, telling you you have water in the system. Unplug the sensor until your next filter change and don't screw it on so tightly. Or back it off a bit currently. I don't run a sensor anymore as it seems to be just another circuit to go bad on my truck. I run an FS1221 filter that doesn't have the sensor port in the bottom.
Old 02-24-2010 | 12:49 PM
HappyCamper's Avatar
A wet connector will also cause a problem with the light coming on. Make sure it is dry
PADuallyBoy
12-17-2008 12:50 PM
booman70
10-30-2008 06:25 PM
kas83
0
11-03-2007 05:35 PM
aicomp
06-02-2006 09:19 AM
robert chilton
01-15-2006 04:59 PM
Quick Reply: WIF Light
