Where should I get 4" exhaust?
Looking for good price and quality...Let me know what you have and how you like it. If its a 3" downpipe into a 4" pipe that is fine as well. I need from the downpipe to the front of the muffler (Im running stacks)
Thanks
Brian
Thanks
Brian
I have the BigExhaust.com system. I love it. It has a 3.5" downpipe into 4" the rest of the way. They sell it in pieces, too, which would be perfect for you. It fit fine, You will need to hack off your old mounts and reattach them to the new system. I don't have a welder so I just left tabs of the old pipe on the hangers and used muffler clamps to hold them in place.
I believe the big exhaust system has a 3" downpipe, i put one in about a month ago, and i was aware that the downpipe was the same size as stock so i just reused my stock downpipe and it slid right together. i saved 90 bucks on the deal.
at 350 bucks im wondering if this system is worth it or would a muffler shop be ale to make something up? i dont really need the down pipe i dont think.
does it just use normal exhaust clamps rather than welding?
jiMMy
jiMMy
Muffler shops typically can't bend anything bigger than 2.5 inch pipe. I used plain 'ol muffler clamps on mine, but you could weld it up if you felt like it. The downpipe is nice to have if you're going to use a wastegated housing on the turbo because the flange is a beefy piece that's welded into the end of the pipe. I was able to cut the pipe back and have the flange welded back in to make room for the longer turbine housing.
sounds like a plan. my only hang up is the kit goes for 350. but for 170 i can buy everything but the down pipe. does that look right.
http://shop.ivalueinternet.com/bigex...uct_id/806.htm
jiMMy
jiMMy
yes no muffler. i still havent ordered anything yet. not have looked at teh truck in a while are all the downpipes 3 in? if so i really wouldnt need the 100 dollar down pipe then i guess. looks like i just need the 2 extension pipes, the muffler replacement pipe and the over the axel tail pipe?
jiMMy
jiMMy
Alec- They said it was a 3.5" downpipe when I ordered it, I never actually measured it but it was larger diameter than the stock downpipe. Maybe I'll crawl under the truck with a set of calipers tomorrow just to see how big it really is.
wonder how well that kit would fit around my transfer case. anyone with a manual 4x4 or 727 auto try this kit? I figure the 518 4x4 would give you more space to work with down there.
Originally posted by NeedMoPower
I'm also curious as to how the 4in system fits on a 4x4 truck. I would like to hear what problems (if any) people with a 4wd have had with it.
Cody
Cody
jiMMy
VikingDiesel
149
12-17-2013 12:51 AM
Idaho Guy
11-12-2011 09:08 PM
treadway47025
38
03-12-2008 11:16 AM
PEAKSTRYDE
10-11-2007 05:20 PM
Hemlockusa
01-28-2006 08:07 AM
