where to locate close to stock front sway bar bushing
The (2) U shaped ones that mount on the frame. What's weird is I mic'ed the stock sway bar at 1 1/8", and an 1 1/8" aftermarket does not completely (a stab on type) encompass the sway bar, and the new U shaped, flange type, clip that accompanies the bushing that bolts onto the frame does not match the size of the OEM clip. Really, I'd like to go aftermarket, one with a zerk and is greasable. Any recomendations?
Check with Johnny at polybushings.com
I just ordered a set for me 1992 W250 CTD last week. He also has the poly bushings for the ends of the sway bar were the vertical rod drops down to the spring plate.
Jim
Jim
part number is 5.5140g, it's an energy suspension kit. had everything I needed. I got it for 29 dollars and some change from sfx performance.
That kit does have grease-able bushings
Tiara3100
11-13-2007 11:20 AM
