where to get pistons
yeah i spoke to a guy from mahle and he said "pretty much indestructable" but understand what he means. some people can wreck anything. what is the difference between the ic and non ic pistons? and what kind of a difference will the bigger pistons make for my truck, if any?
They have a bigger bowl, some people call it the "cowboy hat" style. They are supposed to be better for performance use.
What are you plans for the truck?
does the "hat" change the burn or the comp. or something? i plan on driving home to san diego from new hampshire and then down to the tip of baja for a surf/fishing trip. from there it will be used as a fun dd.
I know they are close, I think the Non-IC might be 16.5:1 and the IC 17:1 but dont hold me to it. If I had to buy pistons for a engine build from stock to mild (800hp) I would go with the Non-IC pistons hands down.
Jim, you are correct. And after alittle research all VE trucks had the same 17.5:1 compression ratio.
The non-ic piston as a wider but shallower bowl. It is designed for the 155* spray pattern.
You can get replacement pistons from Mahle, too. They have lots of pistons for the 5.9. Now you are gonna have to figure out wich ones you want. I'd use the non/IC version.
I don't even know if you can just go buy the monotherms, I think there is a waiting period.
I am pretty sure the valves are next in line of failure after the pistons.
If you read there ads, it says something like they "virtually eliminate piston failure". So for $3K they still won't guarantee it.
If you melt them down, it would be nice if them would replace them.
If it were a mechanical failure, like a rod lets go or valve drops, then it's on you.
I suppose if you have enough supporting mods to melt them, $3K for new ones is probably minor.
I remember Pulltilbroke said to get some industrial pistons because of there bowl shape. Also I've heard you can get them coated to handle more heat? sounds like cheap insurance to me.
DodgeRam24V
13
10-27-2011 11:28 PM
Tuf-4x4
14
01-01-2008 11:35 PM
ddestruel
05-10-2005 12:17 AM
