Where to buy new Master Cylinder and Booster combo
Hey Guys,
The advanced search function seems to be broken. Every time I click on it it opens the K&N website.
Or is that a value added feature to the DTR site?
I was looking into buying a master cylinder booster combo, but I can't search for anything because of this weird K&N thing.
My brakes suck like lots of people and I read in one post that hit my condition on the head, and I followed it up with some other reading (back when I could search) and I want to buy a new not reman'd MC combo.
So far the only thing I could find was a reman on Summit
http://www.summitracing.com/search/s...keyword=master
Thanks
Thanks
If I have to go with a reman what's the best source? I'm not the biggest fan fan of Cardone.
Geez, and Centric has 3 different part #'s
1991 DODGE W250 PICKUP 5.9L L6 DIESEL Turbocharged : Brake/Wheel Hub : Power Brake Booster Price Core Total
ACDELCO Part # 14PB4368 {#19287068} DuraStop; Reman
BOOSTER,P/B (VAC) ; EXC MASTER CYLINDER
* Stocked in outlying warehouse--shipping delayed up to 5 business days
$75.99 $10.00 $85.99
A-1 CARDONE Part # 5473360 Reman. A-1 CARDONE Vacuum Power Brake Booster w/o Master Cylinder One of our most popular parts
Part Image
$61.89 $25.00 $86.89
CENTRIC Part # 16080244 Reman
Engine VIN 8; 3/4 Check Valve With 2 Ports, Master Cylinder Has a Plastic Reservoir, Rod Codes 13849, or 14177
Engine VIN C; 3/4 Check Valve With 2 Ports, Master Cylinder Has a Plastic Reservoir, Rod Codes 13849, or 14177 (Only 1 Remaining)
* Stocked in outlying warehouse--shipping delayed up to 1 business day
$82.79 $25.00 $107.79
PRIOR Part # 3700282 Brake Unit without Master Cylinder; Reman
WT 11; Pedal Rod Code 13851; This Unit may have Several Pedal Rod Codes
$79.79 $38.00 $117.79
A-1 CARDONE Part # 503360 Reman. A-1 CARDONE Vacuum Power Brake Booster w/Master Cylinder One of our most popular parts
Part Image
$86.79 $35.00 $121.79
CENTRIC Part # 16080250 Reman
Engine VIN 8; 1 Check Valve, With 3 Ports, Master Cylinder Is Cast Iron, With Rod Code 14180
Engine VIN C; 1 Check Valve, With 3 Ports, Master Cylinder Is Cast Iron, With Rod Code 14180 (Only 3 Remaining)
$77.79 $50.00 $127.79
CENTRIC Part # 16080245 Reman
Engine VIN C; 3/4 Check Valve With 2 Ports, Master Cylinder is Cast Iron, Rod Codes 13851, or 14180
Engine VIN 8; 3/4 Check Valve With 2 Ports, Master Cylinder is Cast Iron, Rod Codes 13851, or 14180
$102.99 $50.00 $152.99
All the parts listed are remans, but at least they list lots of options.
Part Image
Part Image
Part Image
Part Image
So now which rod code is right?
This is the first I've seen that has different part #'s like this.
Whew
I got a MC, new not reman, from NAPA, it was an "order" part, but only took them until the next day to have it.
I'll see if I can find the receipt( Im bad about tossing them) and get the part number
Heck, google found it right off..NAPA Part# NMC M2326 It was around 100 bucks, but that included the core..
That was for a 93 tho.. but should be the same one for a 91 I would think
new Booster With a MC is part NBB 503360, from Bendex and runs about $120
I take it when you see brake fluid dripping from the front of the booster it's a bad thing right?
I had no clue it was leaking fluid until I looked today, and I bled the brakes a month ago.
Part is ordered and I'll grab it next week.
Thanks
Thanks
turbomike
11-10-2014 11:57 AM
dieselcarpenter
01-21-2010 12:42 PM
Diesel_Dawg
09-11-2007 10:03 PM
