where to buy fuel pin and 3200 spring?
i am wanting to put a new fuel pin and 3200 rpm spring in my truck and was checking to see where you guys get these. found springs on ebay but no fuel pin. truck is lacking a little in the power dept and i have done filter, replaced slide on connectors to ring terminals, also going to put on electric fuel pump. truck is a 98 2500 4x4 with a 92 12v and nv4500 trans. it started life as a v-10 gasser with an auto and changed out. if i run it up to 2k rpm's- it will act like it is not getting fuel, and will not get past 2k rpm. lacks power on hills and when under load. i am going to put new fuel pin and spring in it and see if it helps it out. i am also planning on putting on a fuel pressure gauge as well as swapping out all the fuel lines from tank to pump. any thoughts from you guys on this?
A fuel injection shop will have the 366 (3200) spring for around $15. Which is cheaper than most aftermarket places sell them for. Same situation with the fuel pins. The best ones to consider are those from M&H Inc. or Denny T for about $105.
just put a clicker electric fuel pump on to see if that was my problem......SUNNY-BEACHES!!! runs like a spotted monkey now well now i will plan out the new fuel system for a permanent fix. i was thinking of by-passing the mechanical pump completely and just having the electric pump with an in cab gauge. also going to put the same blue wrapped fuel line that is used on semi tractors. do you guys happen to have contact info for companies to get fuel pin and spring? much appreciated guys, thanks a ton.
bill
bill
M&H Inc.
http://mandhinc.net/
Denny T Performance
http://www.dennytperformance.com/
For the 3200 spring, find a local fuel injection shop and use the P/N listed in "The Sticky."
Denny T Performance
PeytonMaterne
08-11-2008 05:25 PM
BigWaylon
10-07-2006 06:28 PM
