Wheel offset
Wheel offset
What aftermarket wheels will fit on 1992 W250. What should the offset be? Am currently looking at Eagle alloys series 101 16x8" with -20 mm offset. anyone know if these are the corrrect offset? Looking to run 33" diamiter tires.<br><br>thanks for any information.<br>
Re:Wheel offset
do you mean backspacing?? You should measure the stock rims, turn it over so you lookin at the back and measure the distance from the area the rim contacts the hub to the edge of a board or? laying across the back bead area of your rim. The stock 285s are closr to 33 tall just skinny. My 93 wouldent take a wider rim or large backspacing, it would destroy my front fenders and the tries without some serious sheet metal work.<br> Good luck.
johnr9q
06-04-2010 12:54 PM
