Whats a good electric fuel pump?
Exactly what it says. Im looking to put a good fuel pump into my rig that will keep up with everything I want to do. Injectors are in the future.
Ive heard good and bad about the Holley blue pump but the price is right. What would be better?
Part #'s please for pump and regulator.
I just replaced my IP and don't want to do it again.
Thanks for your time.
Yuri
Yuri
I would suggest a 2nd gen piston pump and a bypass regulator. Simple and reliable.
If you want electric, it's hard to beat the Walbro 392 for the price. Again, a bypass regulator after the filter is what you want.
I don't have a 1st gen but if I did I would convert to piston lift pump, you can get one that is correct for a 1st gen. here is a link with pics & part No's of the conversion. https://www.dieseltruckresource.com/...ht=PISTON+PUMP
Gaza
Gaza
In the how to from BC847 on the pistonlift pump it does not mention a fuel pressure regulator. How much pressure would that pump run?
Thanks all
Thanks all
i have a postive air shut off valve in my truck that way if some thing happens it the button and there is no air getting in ,, shutting just the fuel off does not always work
let's see
what does that setup look like? do you have some pictures? where's the valve? [lots of questions, huh?--see there's another one.]
Diesel Girl
18
10-06-2013 03:03 PM
cj5er
12-20-2009 09:19 PM
jesussaves
01-13-2009 08:38 AM
DieselWrencher
09-01-2006 06:27 AM
Sea01Cummer
09-07-2005 09:32 PM
