whats the cummins idle tool look like?
I'm messing with my 91.5 and the idle is a bit high... it's an automatic.
I cannot seem to get at the idle adjustment locknut without removing the fuel bleed banjo and using a deep 10mm socket.
I was hoping someone could make this easier- and how many rpm difference does a turn make?
Michael
Michael
I was able to get mine loose with a craftsman ignition wrench. I then turned the screw with a curved dental pick using the hole through the screw.
SAMIAM- get the correct tool by Schley. You can get it pretty cheap from genosgarage.com. It'll pay for itself in headaches alone. I adjust my idle to perfection at least once a year, sometimes twice. These tools are relatively inexpensive, and for me, make the idle set process a breeze. Only thing out of the ordinary I do is ratchet strap the upper radiator hose to the front bumper, to pull it away. Also, I remove my pumps front return spring, and prop the throttle bracket away from the stop, that way I'm not fighting any sort of tension. Loosen the 10mm lock nut with this tool, and I use a 90 degree needle nose plier to turn the idle bolt in/out. Simple, and no risk of damaging anything.
I have that same tool I bought from Geno's too, Augie.
I am glad to see you on DTR more often there Mr. big.
mknittle (03-05-2017)
When I had my pump apart, I removed both screws and using my Dremel I cut screwdriver slots in the end of them, now it easy to use a small pocket screwdriver to adjust them, it is also easy to use a 90* pick in the small hole at the end of the screw to turn it.
I loosened the nut with the tap of a small sharpened drift punch.
When you have the nut removed, file cuts across the flats of the nut to tap against.
Mkinner
09-21-2010 07:57 PM
04ctd
08-05-2007 05:12 PM
DSjockey
11-05-2005 01:48 PM
