whats the best degreaser?
#32
I'm with Tater93 on the simple green, after using it at work, and have any of you seen his truck? He must be doing something right. No pressure washers, gloves, fires, or worries, and let me tell you it smells great!
#33
One more vote for Purple Power. Spray it on good and thick, I mean use a ton of it. Let sit for a couple hours. Dump lots and lots of hot water on there from a bucket, repeatedly. Then spray with pressurized cold water. Repeat the whole process if necessary.
#34
I have never had to work that hard with Simple Green. Just spray it on and wash it off. Thanks for the compliment Schamran.
#35
Really guys, look at Tater93's truck, and tell me that Simple Green isn't some really good stuff. It won't eat anything if you leave it too long or forget to rinse an area or something. -and it actually smells good.
#37
No Prob. You have the cleanest 1st gen *I've seen* in person or in pictures. Do you even drive it? That's not original paint is it? I have heard you wax your engine compartment.
#39
wow ..no one has said brake kleen .... i work with an ambulance mechanic ..and he don't buy anything but cases of brake kleen and it cleans EVERYTHING... he uses that non flamable stuff ...it's good stuff ..and so far as we've seen.. it hasn't harmed any electrical stuff or anything, of course ..we only use it where it's needed .. we don't bathe the ambulances in it.... typically the underbody
#41
http://www.brewracingframes.com/id75.htm
Here's from OSHA http://www.osha.gov/doc/outreachtrai.../weldhlth.html
CHLORINATED HYDROCARBON SOLVENTS
Various chlorinated hydrocarbons are used in degreasing or other cleaning operations. The vapors of these solvents are a concern in welding and cutting because the heat and ultraviolet radiation from the arc will decompose the vapors and form highly toxic and irritating phosgene gas. (See Phosgene.)
PHOSGENE
Phosgene is formed by decomposition of chlorinated hydrocarbon solvents by ultraviolet radiation. It reacts with moisture in the lungs to produce hydrogen chloride, which in turn destroys lung tissue. For this reason, any use of chlorinated solvents should be well away from welding operations or any operation in which ultraviolet radiation or intense heat is generated.
Phosgene is what was used in the trenches in wwi and caused such horrific problems for the troops. Many guys suffered death or permanent disability.
This gas is also produced when heating the old r-12 refrigerant used everywhere.
#43
i use lianda 217 chemical degresser. it comes in a 55 gal drum and costs 500. i mix it 75 parts water to 25 parts 217 and spray it out of a garden sprayer. it works great, but it will take off clear and etch alumium.
#44
wow ..i guess i never heard of that stuff happening .... that can happen with using brake kleen? it's not like spray everything down with brake kleen then quick grab the welder ... but i guess weird things have happened .... thanks for the info i'll pass that on ....
#45
we use some bad to the bone stuff when we wash logging equipment, it comes from bce cleaning systems in calhoun ga. dragon slayer is the best all around ive seen, just dont get it on bare metal. (its like purple power on roids) Then we have some stuff called smoke house, it will clean powder coating off lol, dont get it on anything unless you are ready to paint it
dizzel
08-02-2007 08:47 PM
EverydayDiesel
19
08-02-2007 05:36 PM
djp9747
17
03-13-2005 02:47 PM
