What would it take to make this nv4500 work in my truck???
http://phoenix.craigslist.org/pts/615729296.html
Is it possible to convert it back to a cummins input and to 4x4?
I THINK that the transmission for the cummins has a larger bore for the input shaft bearing. Either way, you would have to buy a new main-shaft and tail housing assembly to convert to 4x4. Swapping the main shaft is basically rebuilding the transmission.
It is not worth more than core value to you, IMO.
4500 conversion
hey mike, keep in mind the 4500 mainshaft, should be part of your investment, upgrading to the slotted keyway, uses a lockwasher to hold the 5th gear on, advance adapters has the bellhousing that allows your original clutch, i get deals on input gears from a trans rebuilder in oregon, you want their number?
arren333
08-27-2011 08:27 AM
bobem12
02-17-2009 05:13 PM
wcbcruzer
03-25-2008 10:55 AM
CL2000
10-20-2007 04:34 AM
