What top turbo?
Old 02-15-2010 | 08:58 PM
Ahineman's Avatar
What top turbo?
I recently bought a set of Buddha Power 6x.016 injectors to run in my '93. I'm going to run the 12mm pump with my setup...no plans of ever going 14mm. I've also got a whole list of other things I need to buy like 1/2 fuel line, head studs,etc.,etc. I drive the truck a lot, its just going to be a fun daily driver. Two wheel drive so no sled pulling, getrag so not the best drag racer (might see what it will do at a local 1/8 mile dragstrip though). So...
What turbo should I run over a 171702 S400? (It's a 2.9"/3.4" turbo)
I've really been thinking about a Holset Super 40 and I know where I can get a new one for what I think is a good price. Would I be better off with some sort of S300? I'm not really looking at the HX35 because I've been told it will be a restriction.
What do you guys think?
Old 02-15-2010 | 10:29 PM
SuperiorRam's Avatar
s300g 57/65/14
Old 02-16-2010 | 11:51 PM
Ahineman's Avatar
Whats the best place to get one?
Old 02-17-2010 | 02:23 PM
Rollincole's Avatar
for a fun daily driver its hard to beat an he351 off a common rail they spool up lightning fast and drive pressure stays right around 1:1 til about 70 pounds the 9 cm housing is a little restrictive but with only running a 12mm pump you will need way more fuel before you need any more air and thwere cheap
Old 02-17-2010 | 04:17 PM
93Fury's Avatar
I'd say a 300/400 would do good. I believe bgilbert is running a 300/400 combo, he seems do alright...
If you don't mind me asking, what was the price on the injectors from Buddha?
Old 02-19-2010 | 10:45 AM
Ahineman's Avatar
93Fury, you've got a pm.
Old 02-19-2010 | 10:58 AM
bgilbert's Avatar
I'd vote for the hx35 if you're staying with a 12mm pump. You could always go to a 21cm housing on the hx35 if it gets restrictive.
Old 02-19-2010 | 11:55 AM
unixcowboy's Avatar
Why not try a HE351VGT ?
Set up a manual control for the turbine. That way if you want to play you could close down the exhaust for a really fast spool, and when you're running normal or on the hiway you could open up the exhaust for less restriction...
Old 02-19-2010 | 12:34 PM
Ahineman's Avatar
I think the variable turbo is cool, but setting up normal twins will be more than enough for me to figure out. Bill wont the hx35 with a big housing spool slower than the super 40 with the 16?
Old 02-19-2010 | 03:26 PM
bgilbert's Avatar
I doubt it. Possibly the same if not a little quicker with a hx35-21. If you can get your hands on a 14cm wastegated housing that would be where I'd start for a quick spooling twin set. If not, try a heavily ported 12cm wastegated housing.
Old 02-19-2010 | 03:40 PM
Ahineman's Avatar
Is it worth it to put the 60mm compressor on the hx35?
Old 02-20-2010 | 10:15 AM
Ahineman's Avatar
bump
Old 02-24-2010 | 10:24 AM
Ahineman's Avatar
Talking
Well, I ordered my turbos on Monday. I ended up going with the s300g over the s475. Part numbers 174430 and 171702. Less than $1500 shipped. I did a little more research... the 57mm s300 should flow about like the hx40, spool about like the hx35, and be tougher than either one. It wasn't much more money than buying a new 14cm gated exhaust housing and hybrid kit for an hx35...and I'd still have to buy the turbo to put them on. Thanks for all the helpful posts!
Old 02-24-2010 | 11:45 AM
Richie O's Avatar
366 Spring Chicken
I have the 174430 as a single unit. I bought the stock unit from borge warner.
Old 02-24-2010 | 12:07 PM
Ahineman's Avatar
Cool. How do you like yours? What is your max boost and egt?
Quick Reply: What top turbo?
