what to look for when buying a first gen
Guest
Posts: n/a
I am looking at buying a d-350 auto 2wd extended cab with 214,000 miles on it.It has never had a new tranny and the present owner bought it new.It has a goose ball so im saying it has pulled a few heavy laods.The motor only has 83,000 on it(?).
Im not new to cummins but not an expert yet.Any help would be appriciated.
KDP?Tranny issues?Injector pump issues?Suspention?Frame issues?
I am going to look at it Saturday.
Thanks Chris
Thanks Chris
Transmissions are decent but the factory torque converters are mushy(mine is getting changed real soon) and the flexplate is questionable and they ride kind of rough compaired to newer trucks but i like mine.
There's not really an Achilles heal to look for in a first gen. What price is he asking? Thats whats important. This things can be rude, crude, noisy, and bruising.
The 4x4 suffer from cracked frame at the steering box. You should check for the cowl cracks. Worn out door hinges. slushie torque converters. The radiator can get plugged at this age. Definately want to know if he KDP'd it.
Its like this if he's selling at a high price, check it out and make the guy fix any problems or come off his price. If its a low price, you get what you pay for.
I bought my truck with 219k and have fixed only minor issues. Brake pads, wiper motor bushing, battery, ball joints, tie rod. I pretty much have to fix something every month or two. Its expected because its 15 years old and worked hard.
The front suspension on the 2wd's can need a lot of work. Mine needed ball joints, tie rods, and control arm bushings. Look all that stuff over carefully, because it can add up fast if you don't do your own work.
Watch out for rust over the windshield. If there is any, walk away, they rust from the inside out up there. Floor rust is often a sign of cowl cracks, but the D models don't seem as prone to them as the W's.
virginiaram
11-20-2011 09:08 PM
Supertrucker78
02-19-2011 04:43 AM
toupee
06-06-2008 08:55 PM
mopar-or-no-car
09-18-2007 06:19 AM
Dan Brooks
13
08-03-2005 01:27 AM
