What kind of turbo is this?
What kind of turbo is this? It is a Holset, I was told it's off of a 10 L cummins semi truck. It is supposedly HUGE.
[IMG][/IMG]
[IMG][/IMG]
I'm trying to find som info about it before I buy it. Thanks
[IMG][/IMG]
[IMG][/IMG]
That is huge. If i read the numbers right that has a 22cm2 housing on it. unless you have a lot of extra fuel and i mean a lot than i don't believe you could productively use it.
What would be a good turbo to put above it? right now I have a HX50, Monster Garrett, and my stock H1C laying around. Would an H1C/HX50 setup be worth it's weight in poo?
Put the 50 over the moster garrett. Personally the h1c/50 would be too close in size to run as twins. They sure would light quick but you would suffer on the top end.
The H1c is no longer an option as I blew it up today. Turned the hot side into shrapnel. There is no way in edit I could spool the 50 (66mm/19cm) on top of the garret (74 or 76mm/~22cm) exhaust. I would prefer to use the 50 as a single but I have beat that subject to death.
LemonDodge
12-02-2007 10:45 PM
Dodgezilla
15
10-18-2006 08:19 PM
