What kind of difference have people noticed w/ 366(3K) governor springs?
I ask because besides being able to rev higher and being a little smoother its pretty much the same. I have the full fuel screw in the same spot, unsure about the idle stop screw, the high idle screw was already backed off and the linkage adjusted. If fact I actually lost boost and gained EGT, but it was about 20deg warmer and more humid out when I tested it w/ the spring. I get about 26 psi and am at about 1200 deg pre turbo in 4th gear hitting it at about 1500 and pulling to 3000. before I was at 29 psi and 1000 deg, but defueling earlier. After I bump my timing I guess its time to buy some parts, injectors, turbo...
I didn't see any power increase. Just a better shifting tranny. With the automatic and a stock torque converter, the truck tows a lot better after I readjusted the TV cable and the TPS. ALso I noticed a snapper response when it shifts. Overall I am pleased with this mod. (especialy at highway speeds.)
OK, sounds like my truck acts normally w/ the spring, I read somewhere a while back how the spring made a huge difference on someone's truck, but I think they had turbo/injector upgrades.
I'm also running the 3k spring as well instead of the 3200rpm spring. I imagine we don't notice as much of a difference as most as we only gain 200RPM over stock. The 3200 gov spring gives 400 more RPM and is probably a more noticable difference. I'm planning to go upto the 3200,
Originally Posted by jrussell
I thought the 3k and 3200 were the same spring, just with different names? Aren't they both a "366" spring?
Ok I have the 386 spring which is where I think I was confused, I think the 366 is the 3200 spring and the 366(which I have) is the 3000 spring........ I think.
Originally Posted by flashgordon
So we can by springs in 200 rpm from stock 2400, to 3200?
