what keeps worm gear in transmission in sync w/ drive shaft
is the worm gear, in the t-case that drives the output shaft that drives the vss, supposed to be locked in w/ the drive shft or what. i been havin a problem w/ my speedo and i can stick my finger in the hole and spin the gear around the shaft while in park is that normal.
i dropped the drive shaft and and tightend the nut as much as i could but i can still spin it.
got that
but what keeps the worm gear from free spinning around the output shaft of the t-case (ar trans.)
i removed all the vss, gear reducer, the dive gear that goes into t-case stuck my finger in the hole and can rotate(easily) the worm gear around the t-case output shaft.
should you be able to rotate that or no
No, that gear shouldn't turn if the shaft isn't. I think it's splined on there (I've had mine apart but you know, brain like a steel sieve). If you pull the yoke and output bearing (little aluminum housing has to come off, 5 bolts) I think you can reach in there and slide the gear off the shaft.
thanks brainfrade
anyone got any ideas where to get 1
dealershio is no help (wolfchase dodge memphis, tn)
i'm about to just take it to a trans shop and just get the trans and t-case oils changed to, BUT you know the song and dance
got more time than money
alwaysonDTR
http://i289.photobucket.com/albums/l...s/DSCF4500.jpg
yes its splined on the output and i think you can pull the stuff like brainfade said.
thats for the photo,
unfortunately i found out the hard way i is actually ok
guess i'll have to keep searchin for the problem.
got a new pcm-no sppedo, no overdrive, shecked signal from driven gear, ratio adapter, and vss all seem ok
it's 92 w250 auto.
broke pcm or speedo maybe
it wasn't charging - until i replaced the pcm a/c functions also
was using cruise and had o.d. (light does functions on dash) but since pcm went out and been replaced the c.c. (light on dash wont come) od speedo haven't come back
got good continuiety from vss end to dash to pcm....
nutty huh
nutty huh
HONDA99
08-04-2010 02:21 PM
Dan_K
05-20-2005 06:45 PM
