Old 09-19-2015, 10:27 AM
  #1336
peckens's Avatar
Originally Posted by j_martin
Who has good ones?
I would like to know also! Right now I am trying to reattach one of the clips 1/8 of an inch lower so it stops pushing upward and inward on the corner where the door lock is.
Old 09-19-2015, 03:05 PM
  #1337
Received 1,334 Likes on 864 Posts
Who has good ones?
The ones I got from JC Whitney were good quality. I would think LMC would probably have good ones as well?
Old 09-19-2015, 05:14 PM
  #1338
peckens's Avatar
Well if I cant get these fairchild ones to work ill buy the JCW ones. My problem is the corner that curves upward sits too low and when I roll the window up it pushes out by about 1/4".
Edit: Ended up using double sided loctape on that end. works better than the crappy clip design.
Old 09-20-2015, 05:58 PM
  #1339
Received 1,647 Likes on 1,120 Posts
Finished updating my new relays for my headlamps, and snow plow headlamps. Upper and lower beams are now separated by different fuses and relays. Since the new relays are now sealed, I shouldn't have to do this again.
Old 09-20-2015, 07:36 PM
  #1340
bigragu's Avatar
Hey, T! I see that you, too, have a fancy shcmancy labeling machine, and you like to label things! Are you particular about font size and spelling as I am?? What's bad about me is, I go crazy with those yellow paint pens. If the handwritten font don't look good, it causes me to lose sleep!!
Old 09-21-2015, 11:43 AM
  #1341
Received 2,536 Likes on 1,677 Posts
T-man
What is with the one phillips head screw?
Your going curse yourself when you need two different screwdrivers to remove them.
Did you not have 4 matching screws in the misc. nut, bolt and screw jar?
Your work is usually so cleanly executed.
Okay serious now…
That is looking great and should go a long way to helping keep the salt and such out of the connections.
Old 09-21-2015, 02:45 PM
  #1342
T-man
Okay serious now…
Hahahaaha..........I had not noticed that....
Old 09-21-2015, 05:29 PM
  #1343
I knew you guys were going to bust me on that one.
I had 4 of the same, lost it, and mounted them.
I then found it, but thought one of you pineapples would find it interesting..... and I was right.. It's since been changed to all the same 5/16 drive with a slot.
Old 09-21-2015, 05:39 PM
  #1344
Old 09-21-2015, 08:12 PM
  #1345
T-man,
I knew something was up as that was not your style.
My pineapple IS easily amused, and I am okay with that.
On a side note:
I have been driving the '91 at night a bit and just found out the high beams work on and off when you hit the column multi function lever.
Seems to come and go, as you can flick the lever a few times and get them to work again.
I am thinking it might be in then multi function lever itself, but I have not had time to look into it yet.
Or... maybe it is a bad ground as Dodge trucks have a problem with that.
Anyone else have this issue?
Old 09-21-2015, 09:23 PM
  #1346
j_martin's Avatar
T-man,
On a side note:
Wouldn't likely be a ground, as no ground is carried through the switch. Most likely eroded contacts in the switch itself, which likely has a quarter million miles on it.
The stock headlight grounds are pretty cheesy, though. Wire is way too light and too long. A bad ground there would affect high and low beams equally, on one side or another.
Old 09-21-2015, 09:52 PM
  #1347
Thanks j_martin!
You are right, it does has 240,xxx on it.
That gives me a better plan of attack, as I have a few spare multi function lever set ups.
I will start there.
Old 09-21-2015, 10:10 PM
  #1348
j.fonder's Avatar
Thanks j_martin!
I will start there.
i'd squirt some contact cleaner in there and work the switch around.
as I was typing this i realized that you said you have spares...
Old 09-22-2015, 07:32 AM
  #1349
The other day, my ignition switch had a brainfart.
I turned the truck off, pulled the key out, and the "key in ignition" buzzer was still buzzing. Jiggled the cylinder forwards, and it went off.
Really weird. No key in it, and it still buzzed.
Old 09-22-2015, 07:42 AM
  #1350
j.fonder's Avatar
Be careful, those cylinders like to break off inside, key will turn and maintain the "on" position but won't turn over the truck. Had to replace my cylinder about a year ago.
Quick Reply: What did you do to your Gen 1 today?
