Old 04-05-2014, 08:57 PM
  #106
d9inger's Avatar
I know it's unrelated but I spent the last two days working on my 2001 diesel VW Jetta... New timing belt, water pump, all roller bearings, cam and crank seals, etc.... 5th TB change, 420,000 miles and going strong…. Whoop Whoop!
OK back to the Dodge subject.
I have Hella headlights on order along with relays etc. Going to do the https://www.dieseltruckresource.com/...s-t176263.html mod as soon as I recover from that TB Jetta thing..
Dave
Old 04-06-2014, 12:45 AM
  #107
simplysmn's Avatar
finished taking my 93 part's truck apart a Caddy took it out can't believe how twisted the frame was .it was hit hard right front corner and the floor board was split at the seam and heater box was in 5 pieces pretty hard hit and the guy claimed that the body shop said they could fix it . There is No way this 1 was fixable thou .not even Duct Tape would help . LOL
Old 04-06-2014, 09:05 AM
  #108
Jim5870's Avatar
I'm having a look today to see why my
overdrive kicks in and out.
Going to make a wire connector to the overdrive
into the cab so I can test it with a toggle switch.
Trying to see if the problem is tranny or control circuit
Old 04-06-2014, 04:03 PM
  #109
oliverbutthead's Avatar
Took out the Getrag and transfer case yesterday. Cleaned all the grease and grime off today. Was really caked on bad. Taking the getrag to get rebuilt tomorrow due to losing all gears except for fourth. Going to replace seals in the NP205 since it is making it pretty dang dirty under there due to a slow leak.
Going to replace clutch while everything is out with a Sachs when I get it in the next few days.
Old 04-06-2014, 04:36 PM
  #110
mknittle's Avatar
I cleaned up my transmission wiring harness. I also started started soaking my spare chrome mirror parts in Clorox to remove the remaining chrome. Then I will paint them trim black and replace the mirror glass.
Old 04-06-2014, 10:18 PM
  #111
Received 2,536 Likes on 1,677 Posts
Got the custom secondary hood latch dailed in, finally.
Then got the hood to close nicely and the grille test fit over the 24V intercooler.
I have a little work to do to the back of the grille and I am off to button up the EGT and Boost gauges in the cab.
Old 04-07-2014, 08:40 AM
  #112
mknittle's Avatar
got any pictures of the hood?
Old 04-07-2014, 10:17 AM
  #113
aicomp's Avatar
Hey Val,
i know of a Great cab and frame.
I am spraying Lizard Skin on the floors of the '92 today. Have the headliner at my friend's upholstery shop.
Old 04-07-2014, 09:17 PM
  #114
Received 1,334 Likes on 864 Posts
I'm going to be doing up the gauges in the crewcab in the next few days. Where are you running your 12V ignition source, and lights from?
Old 04-07-2014, 09:21 PM
  #115
aicomp's Avatar
Got the new carpet laying inside and unfolding from shipment. Made the cad files for the winch bumper and cut the top and bottom out on my CNC Plasma table. I will start welding on it tomorrow.
Mike
Old 04-08-2014, 06:52 AM
  #116
I can send you a picture of my custom secondary/saftey hood latch to an E-mail address. If you would like that PM with your E-mail address.
I don't have the computer skills to load pictures on here.
I basically cut 1 1/4 inches out of the center of the latch, then welded back together.
I then ground down the hook end, so it didn't hit the huge 24v intercooler hiding right below the upper lip of my '91 core support.
It took me awhile to get it just right, and still be able to open it with the grille on.
Old 04-08-2014, 07:09 AM
  #117
I am making one of Autometers 1st gen two gauge A-pillar pods work on my '85 crew.
It is designed to be used on the later 1st gen trucks with the a-pillar trim, but I can get it to look good without it.
I ran the wires behind the dash and down to the fuse box where it is soldered and shrink wrapped onto the wire off the back of the 3 AMP fuse at the top of the box.
I can send you a picture to an e-mail address as well if you like.
Old 04-08-2014, 10:25 AM
  #118
mknittle's Avatar
hopefully welding up part of my front spring hangers.
Old 04-08-2014, 07:40 PM
  #119
Jim5870's Avatar
Made a test switch to determine if my overdrive problem is in the trans
or control circuit, turns out my problem is on the control side, trans works fine. Going to check the wiring next.
I also took my truck to the spring shop, turns out it had 5 cracked leafs.
I wonder if hard launches have something to do with that?
Sure sits higher in the back now.
Old 04-08-2014, 07:51 PM
  #120
simplysmn's Avatar
Mike
Hey Mike I want to see Pictures I may have you build me 1 to match your's
Quick Reply: What did you do to your Gen 1 today?
