Old 02-20-2021, 05:08 PM
  #8191
Received 2,536 Likes on 1,677 Posts
Edwin,
That HX-35 should have a 12CM housing just like your WH1C would have from Dodge.
edwinsmith (02-20-2021)
Old 02-21-2021, 08:44 AM
  #8192
jimbo486's Avatar
Those are speed holes now...or maybe whistles at the right speed...
Coyote whistles where I'm at lol.
Old 02-23-2021, 11:15 AM
  #8193
Shelby/Dakota's Avatar
Ordered a 98 Express van hydrobooster M/C combo. Tracked down adaptor fittings for P/s pump and steering gear. Need to verify booster threads so i can get adaptors for it. Then hopefully it is a fairly straight forward install.
Old 02-25-2021, 07:54 AM
  #8194
Grant31781's Avatar
I installed a diamond eye 4 inch turbo back stiraight pipe exhaust. It was too loud so I added a $70 Amazon muffler to it and now its just right. I also adjusted my idle back down since turning in the fuel screw 1 turn increased the Idle rpm. I also deleted the AFC by removing the spring. If I floor it it will black smoke some however it is easy to control the smoke by listening to the turbo vs foot position!
Old 02-26-2021, 04:44 PM
  #8195
Gunch's Avatar
My limited slip rear has been making a cracking noise when pulling out and turning.So I Got some rear additive and put in today to see if this helps
Old 02-28-2021, 02:37 PM
  #8196
Gunch's Avatar
Emergency Brake light
Decided to see if I could get my emergency brake light to work .I thought when I unplugged the black box behind the glove box it killed the power to emergency brake light.Upon wiggling and shaking the wire it started lighting up.So I took the switch out and replaced it with another I had and amazingly it started working.Oh yea and I just love working under the dash of this truck I’m definitely not as flexible as I once was.
Old 02-28-2021, 02:43 PM
  #8197
edwinsmith's Avatar
Received 1,048 Likes on 770 Posts
Two choices here, learn to walk on the ceiling or turn the truck upside down.
I had to install a trailer brake controller recently and my 70yo body works about as good as yours. I still have the scars.
Oh! and There's a switch for the parking brake light??? Maybe that's what the wire is hanging down there.
Edwin
Old 02-28-2021, 05:34 PM
  #8198
Gunch's Avatar
Edwin
Edwin just remember Scars are tattoos with stories and I have a lot of stories
Old 02-28-2021, 05:43 PM
  #8199
KRB
KRB's Avatar
Cummins kinda solved that issue when they mounted that 1st Gen sideways on the wall in the corporate lobby in Columbus. Just open the door and stand up. Course you need a stepladder for it though.
https://www.google.com/url?sa=i&url=...AAAAAdAAAAABAD
edwinsmith (02-28-2021)
Old 03-01-2021, 06:11 AM
  #8200
nonrev's Avatar
Hahaha I wouldn't want to be the one to open that door
Old 03-01-2021, 12:11 PM
  #8201
Taylorm2121's Avatar
My Ebrake light worked fine before I removed the entire Ebrake assembly during sound deadening and new carpet. I out sound deadening material where the two bolts go thru the firewall. Reinstalled everything and now the Ebrake light doesn't work. Haven't tried to figure out why yet! I agree, working under the dash is a pain, I was upside down and figured out quickly, my 50 year old ain't what it use to be.
Old 03-01-2021, 01:13 PM
  #8202
IIRC there is a one wire plug in on the E-brake foot assembly. I could see how it would have been unplugged when you pulled the kick panel and did the carpet work. It lights up when the pedal is depressed or not all the way up.
That would be the first place I would check.
Old 03-01-2021, 02:37 PM
  #8203
You are correct, I made sure that one wire was definitely reconnected during reinstallation. There are a couple copper wings on the switch, I need to make sure they didn't get bent out of shape.
Old 03-29-2021, 08:51 PM
  #8204
N. Besonderes's Avatar
Twin sticked my NP205. Got the kit from JB Custom Fab. Quality stuff.
-Niemand
FrustratedFirst (04-30-2021)
Old 03-29-2021, 11:52 PM
  #8205
edwinsmith's Avatar
Why are 2 sticks better?
Quick Reply: What did you do to your Gen 1 today?
