Old 02-09-2021, 03:49 PM
  #8176
FrustratedFirst's Avatar
Originally Posted by Ryan Stuchly
I have driven it on one rainy day so far here in Texas and it acted 100% normal.
I do not have any technical answers to that question though, it handles great overall.
Nice Ride! Welcome! See the palm trees in your pics. Curious what part of the Great State you are in?
Old 02-13-2021, 02:13 PM
  #8177
edwinsmith's Avatar
Received 1,048 Likes on 770 Posts
Fuel issue solved (fingers crossed)
I ran the tank down past 1/2 full without starting issues so I hope the issue is solved. After I cut a hole in the bed and took out the pickup/heater/gauge assembly I found a handful of crud plugging the screen on the end of the pickup tube. I put in some strips and welded them to the sides of the hole then I used threaded inserts in then strips to make a removable cover in case it happens again.
Then it was on to replacing the alternator in the wife's Equinox. It made me appreciate how open everything is to work on the Cummins.
Edwin
The following 2 users liked this post by edwinsmith:
jimbo486 (02-14-2021), ScubaSteveCA (02-13-2021)
Old 02-14-2021, 09:30 AM
  #8178
BHD
BHD's Avatar
Edwin
I just finished putting a water pump in a LLY Duramax. Every time I work on off-brand diesels, I appreciate my old mechanical 5.9BT a little more.
The following 2 users liked this post by BHD:
edwinsmith (02-14-2021), jimbo486 (02-14-2021)
Old 02-14-2021, 12:35 PM
  #8179
Grant31781's Avatar
I just pulled my speedometer due to it not working. Those little gears are stripped so I ordered some more from Amazon. I hope it gets it back working. I also turned in my fuel screw 1 turn, It gave it a noticeable increase in throttle response and a slightly higher idle speed.
Old 02-14-2021, 12:50 PM
  #8180
Received 2,536 Likes on 1,677 Posts
Grant,
Depending on how much you turn in the fuel screw and what your idle was at before it is standard practice to lower the idle after turning in the fuel screw.
The following 3 users liked this post by oliver foster:
edwinsmith (02-14-2021), nonrev (02-14-2021), nothingbutdarts (02-15-2021)
Old 02-15-2021, 08:30 AM
  #8181
jimbo486's Avatar
I replaced my dually fender clearance lights with an LED that is much more sleek looking!
The following 3 users liked this post by jimbo486:
Rug_Trucker (02-15-2021), ScubaSteveCA (02-20-2021), thrashingcows (02-17-2021)
Old 02-15-2021, 02:30 PM
  #8182
edwinsmith's Avatar
I replaced mine with LED's from Walmart 12 years ago. Cheaper that what you got but in OEM package shape. Plug and play.
Edwin
nonrev (02-16-2021), thrashingcows (02-17-2021)
Old 02-16-2021, 09:12 AM
  #8183
jimbo486's Avatar
To each their own, of course. I wanted to get away from the big and dated look of the OEM lights and their typical replacements.
To date, the only incandescent bulbs left on the truck are those in the message center and the glove box light. I'll get to replacing them at some point. At least they're infrequently used.
Old 02-16-2021, 05:33 PM
  #8184
edwinsmith's Avatar
They'll look a lot better when you get the holes patched and painted. They sure look bright!
Old 02-17-2021, 04:28 PM
  #8185
Received 1,334 Likes on 864 Posts
Those are speed holes now...or maybe whistles at the right speed...
edwinsmith (02-17-2021)
Old 02-19-2021, 05:09 AM
  #8186
KRB
KRB's Avatar
Or openings for more lights...
The following 2 users liked this post by KRB:
edwinsmith (02-19-2021), Rug_Trucker (02-19-2021)
Old 02-19-2021, 08:59 PM
  #8187
Rug_Trucker's Avatar
Thumbs up
jimbo486 (02-21-2021)
Old 02-20-2021, 11:48 AM
  #8188
ScubaSteveCA's Avatar
Finally put in the hx35 that I bought and rebuilt. Wish I had the time to do the exhaust at the same time, but at least most of the bolts are broke loose.
I was under the impression that I could keep the wastegate, but it wouldnt clear the oil return line, so I'll have to fab up a spring gate maybe? Its wired shut currently, but I'd like to have some control of it in the future.
Also, your wife may appreciate the fumes of curing paint in the kitchen, mine did not. BBQ next time
Old 02-20-2021, 11:54 AM
  #8189
BHD
BHD's Avatar
You will like that gate nailed shut. Who likes to make waste?
Old 02-20-2021, 05:02 PM
  #8190
edwinsmith's Avatar
What size is the turbine on an HX-35? I cobbled together a WH1C for my rig. I used a boost fooler to set the WG to open at about 34 psi boost. That was before I replaced the VE with one that was set to stock. I don't need the power right now but I probably will when we drag this 5th wheel to Okiehoma. So Steve we can look forward to tweaking both of our pumps. There is extensive info in the stickies to review.
Edwin
Quick Reply: What did you do to your Gen 1 today?
