#6151
Good to know Jim.
I have seen several of his products on E-bay.
#6152
I changed the contacts and brushes in my starter. in the process I found a rattle that developed lately. the left shock mount had worked loose. I also had a couple cab mount bolts that weren't tight as the should be. That done I advanced the timing a little. sounds a lot better.
#6154
I pressure washed Ol' Patches yesterday.....top to bottom. Try and clean off some of that winter crud....man 2 long "real" winters have sure taken it's toll on the truck. Almost scared to drive it another winter.
Once the shop is built I will definitely have to bring it in and tear it down for a good prime and paint on the frame and suspension, then blast, prime and paint the under side of the cab and box, and maybe paint the whole truck.....no more Patches.
#6155
Received 1,647 Likes
#6156
TCows- have you already broke ground on your shop’s construction?
#6157
Got my cast iron extension housing from
. $125 vs $245 from Quad. Exact same part, and it showed up within 24 hours of ordering. Hopefully my new hitch setup will be here by tomorrow and I can make this a major truck weekend. I’ve got a lot of hydraulic cylinders to install, and I need my truck to haul em out to the job sites.
#6158
Not with a foot of snow still out at the house...... But I have everything lined up with a contractor, permits in hand and now just waiting for summer to get here. Plus there is road weight restrictions in effect out here now so I have to wait for them to be lifted before they can start. Probably be mid June before they lift the weight restrictions, contractor wants to start as soon as they are lifted.
#6159
It's a real mix up here....chemical or salt/sand to about -10*C, then it's straight gravel when temps are colder then that. I have had 100x's more wear on the underside of the truck in the last 2 years then the previous 6 years.
#6160
My dodge looked great in my RR conversion thread. Now it's all rusty cruddy looking under there
https://www.dieseltruckresource.com/...y-92-a-301769/
So...... disappointing. I get what you mean.
The following 2 users liked this post by NJTman:
hunterbob (04-19-2018),
thrashingcows (04-19-2018)
#6161
Please promise me you’ll show pics on the progress.
thrashingcows (04-20-2018)
#6162
I'm shooting to have the roof done and the wood burning stove installed, all the doors and windows in and maybe the lower 3rd of the siding before winter sets in. The rest I can pick away at over the winter.
Gonna be nice, but I'm already loosing sleep over the costs.....I'm to tight with my money even when I know it's what I need and will only increase the resale value of the property.
But I will for sure post up progress pics.
The following 3 users liked this post by thrashingcows:
#6163
Still trying to figure this low idle out or maybe it is a bit rough idle,
It all started last week after my fuel pump went out and started dumping diesel into my crankcase.
I drained about 3 1/2 gallons out of the crankcase, let it drain for about an hour then refilled it with fresh Rotella, it ran fine for a day then I noticed the idle felt a little low by just a few rpm's, I an sensitive and can feel slight differences just enough to notice a slight rattle, just the weight of my foot on the pedal and it goes away.
Can lower fuel pressure cause a drop in idle?
Or maybe an air leak on the suction side of the pump?
I took all of the linkages apart cleaned and lubed all of the cables and joints
and then turned up the idle screw to compensate but I would like to find out why it happened.
Also how long does it usually take your freshly changed oil to turn black, mine would usually be black within a few days, I pulled the dipstick to check the level and it was still clear like if I just poured it in, the level was where I left it with no smell of diesel, it has been running for about a week now.
Is it possible that the diesel fuel mix has cleaned out the inside of the block?
Where is the best place to get the tapped banjo bolt so I can check the pump pressure?
Jim
Jim
#6164
I don't have answers to all your questions but I know when I change the oil in the race car it takes a couple weekends of racing before it's back to normal. Funny how little things like that will make noticeable differences.
#6165
Hey Jim.
I thought Genos has those banjo bolts????
