Old 11-07-2014, 10:22 AM
  #571
Received 1,334 Likes on 864 Posts
Originally Posted by Redtruck-VA
Nicely done..
Thank you.
Old 11-08-2014, 04:39 PM
  #572
d9inger's Avatar
My son (16) just took the 92 W250 to a friends, came back home saying the brakes were inop, it's pissing fluid out the rear slave.
Researching......
Old 11-08-2014, 05:02 PM
  #573
u2slow's Avatar
Researching......
As a quick fix, abandon and cap off the faulty line at the junction block. The plugs were $1 or something from the store... or you can weld up the old flare nut.
Old 11-08-2014, 06:41 PM
  #574
Yesterday I installed the aluminum upper wheel opening mouldings from the 84 side trim. I have been debating if I should run the 91-93 big black wheel opening flares. But after my last junk yard run and seeing the dodge rams and dakota with front and rear wheel rot due to these types of flairs, I couldn't justify putting them back on. Especially since this is my daily drivers.
I also installed my aluminum mud flaps. And today I gave Ol' Patch's a bath and some fixes hear and there, mostly where water was leaking in, and some surface rust had started.
Old 11-08-2014, 06:52 PM
  #575
Redtruck-VA's Avatar
Received the air box cover, picked up a 93 filter and a couple 3-1/2" reducers/connectors to fit some tubing up. I really don't like the cone filter that the truck came with.
Old 11-08-2014, 07:45 PM
  #576
mknittle's Avatar
Yesterday I installed the aluminum upper wheel opening mouldings from the 84 side trim. I have been debating if I should run the 91-93 big black wheel opening flares. But after my last junk yard run and seeing the dodge rams and dakota with front and rear wheel rot due to these types of flairs, I couldn't justify putting them back on. Especially since this is my daily drivers.<br>
<br>
I also installed my aluminum mud flaps. And today I gave Ol' Patch's a bath and some fixes hear and there, mostly where water was leaking in, and some surface rust had started.<br>
<br>
<a href="http://s697.photobucket.com/user/thrashingcows/media/84%20Crewcab/November%202014/PICT0423_zps2c21d5ad.jpg.html" target="_blank"><img alt="" src="http://i697.photobucket.com/albums/vv340/thrashingcows/84%20Crewcab/November%202014/PICT0423_zps2c21d5ad.jpg" border="0"></a><br>
<br>
<a href="http://s697.photobucket.com/user/thrashingcows/media/84%20Crewcab/November%202014/PICT0424_zps3ee6d9b6.jpg.html" target="_blank"><img alt="" src="http://i697.photobucket.com/albums/vv340/thrashingcows/84%20Crewcab/November%202014/PICT0424_zps3ee6d9b6.jpg" border="0"></a>
<br>
I like those better anyway.<br>
Old 11-08-2014, 07:46 PM
  #577
mknittle's Avatar
what the.......?
Old 11-08-2014, 09:24 PM
  #578
Originally Posted by mknittle
what the.......?
In reference to what Mark?
Old 11-08-2014, 09:32 PM
  #579
Received 1,647 Likes on 1,120 Posts
The scribble under your post in his reply...
Old 11-08-2014, 10:15 PM
  #580
j_martin's Avatar
Mark. I think you grabbed the wrong link at photobucket. It's easy to do with their new-fangled setup.
Old 11-08-2014, 10:23 PM
  #581
But he was just quoting me from my post. Not sure what's going on there Mark...maybe you have a bug in your 'puter?
Old 11-09-2014, 08:52 AM
  #582
mknittle's Avatar
I don't use photobucket. for some things they did to photographers in the past. Now I have one more reason to not use them.
Funny you mentioned that as I am looking for a photo hosting website for my other hobby. photography.
Old 11-09-2014, 09:00 AM
  #583
mknittle's Avatar
Probably not a bug but a Robin(My wife)
For some reason it has to do with the emoticons. maybe some conflict from her games. that has happened before.
Old 11-09-2014, 12:26 PM
  #584
Went out this morning and finally replaced the cone air filter. Used a 91' filter and OEM air box cover. A 3-1/2" aluminum flex hose and some ducting insulation and tape. IMO, came out pretty good. Also noticed the fuel separator dripping from the bottom sensor. I cleaned up the electrical connector and my wtr in fuel light went out. Pushed (cycled) up on the "drain"? and it stopped leaking. Looked like a little fuel came out put that was it. Doesn't look like it is leaking now.
Old 11-09-2014, 05:56 PM
  #585
Is that dryer vent ?
Won't that stuff collapse under suction ?
Don't know, just asking.....
Quick Reply: What did you do to your Gen 1 today?
