Old 09-23-2016, 09:39 AM
  #2971
1992gen1_fan's Avatar
Today when I went out to get ready to leave to work the front left tire was flat aired it up and drove to the tire shop. Had a very small screw stuck in the tread. $13 later back on the road
Old 09-24-2016, 12:46 AM
  #2972
73CrewCab's Avatar
Today I did some mock up, measuring, head scratching, more measuring, eyeball aligning and a little cutting on the 73....
NJTman (09-25-2016)
Old 09-24-2016, 04:55 AM
  #2973
Jim Lane's Avatar
Easiest repair on any vehicle ever
It is even easier if you replace the bolts using studs, you don't even have to hold it.
Old 09-24-2016, 07:19 AM
  #2974
Blue Goose's Avatar
easy as a Big Block Mopar?
Old 09-25-2016, 06:06 AM
  #2975
Received 1,647 Likes on 1,120 Posts
Received a new Christmas present yesterday
Merry Christmas, Brick. May it serve you well..
Attached Thumbnails What did you do to your Gen 1 today?-0924160904.jpg   What did you do to your Gen 1 today?-0924160906.jpg
Old 09-25-2016, 11:59 PM
  #2976
1320Fastback's Avatar
Buddy told me of some preacticaly new Michelin 265/75R16E tires at a used tire shop so I grabbed them for the front of the truck. $140 out the door and they look great, build date of 2015.
thrashingcows (09-27-2016)
Old 09-26-2016, 12:10 PM
  #2977
twostep's Avatar
Gave the mule a work out this past weekend. Went on a 7 hour round trip to my favorite wheeling spot down in TN. You will notice that I also have the bed back on.
Attached Thumbnails What did you do to your Gen 1 today?-img_1613%5B1%5D.jpg   What did you do to your Gen 1 today?-img_1623%5B1%5D.jpg   What did you do to your Gen 1 today?-img_1635%5B1%5D.jpg
Old 09-26-2016, 12:24 PM
  #2978
PapeCAT's Avatar
Nice new harmonic damper, T. Is that the larger one from the 24V application or the stock small one from 89-93?
https://www.genosgarage.com/product/...cement-parts-2
The 1998.5-2002 one is a mild upgrade that is meant to handle the "H.O." engines of that era. If you're replacing it, it is better suited to handle increased power mods for the VE era trucks, and best of all, cheaper. Think of it as a partial upgrade in lieu of a fluiddampr
Old 09-26-2016, 12:32 PM
  #2979
Blue Goose's Avatar
you didn't show off and pull the trailer thru the mud bog did ya?
Old 09-26-2016, 01:41 PM
  #2980
twostep's Avatar
haha... no i avoid mud like the plague. I did put it in 4low to pull it up the stupid steep and loose hill to get to the campground. Low range and 1st gear... no problem.
Old 09-26-2016, 02:54 PM
  #2981
j.fonder's Avatar
Low range and 1st gear, dang brakes won't even stop the truck!
Old 09-27-2016, 05:16 AM
  #2982
Now you tell me ?
No, but it is the "3rd revision" of harmonic balancers / vibration dampers that cummins changed the B engines to.
Yes, Geno's sent it to me, and the part number is 3916436. Cummins Quickserve shows it's the final revision replacement, and I confirmed it with Cummins prior to ordering. Cummins wanted $285, and didn't have them in stock nearby. Genos had the exact same cummins unit in stock, and at $226.
Can't wait to put it on and see if it makes any difference than my 200,000 unit on there now.
Old 09-27-2016, 09:56 AM
  #2983
Received 1,334 Likes on 864 Posts
Finally got around to replacing that leaking water pump....OMG I can't believe that the water pump was still in one piece! The bearing was completely toast...over a 1/4" play in every direction!
Tossed in another good "used" original cummins water pump and all is well. I also took a few minutes to re-route the return lines on the HB/PS system.
Old 09-27-2016, 09:25 PM
  #2984
Adjusted valves and changed the gaskets.
Old 09-27-2016, 11:02 PM
  #2985
kcabbie's Avatar
Trying to work out the last details. Hooked up the parking brake cables in the dana 80. Made brake lines. Installed the larger chevy wheel cylinders. Little bit on the inside.
Attached Thumbnails What did you do to your Gen 1 today?-20160927_130509.jpg
Quick Reply: What did you do to your Gen 1 today?
