#2206
Thank yall for the replies. I'll definitely put some padding over the sound mat to help with noise then. I like the look and feel of carpet but living in the country with gravel roads and 3 dogs i don't feel like vacuuming every other day as well. Now time to see if i can source a pre molded pad or use the Jim Lane method.
mknittle (03-17-2016)
#2207
#2211
Looks good. I really want to go with carpet. It will just get hastily ruined in my next of the woods
#2212
Cool grille work.
I was eyeing out your shackle flip parts as well the other day. They look good.
ARCHIVE (03-19-2016)
#2216
Received 1,647 Likes
#2217
It lifts the truck without using a lift spring that usually ride stiffer that a flatter stock leaf spring.
Or the big gain for the stock height truck crowd, is you could ditch your block under your spring reducing axle wrap under power.
I have been toying with that idea on my lifted white crew.
Doing a a shackle flip for the rear axle, then loose the blocks to keep the axle wrap to a minimum without adding traction bars.
#2218
Pulled the cluster and replaced all the light bulbs. Also, cleaned the circuit board with an eraser. No signs of corrosion, but now the AMP gauge works. I even got the speedometer hooked up correctly. (the second time...)
#2219
#2220
Vendor - Former Vendor
Oliver explained it well. It also adds greasable urethane bushings at the shackle end, which helps the shackle move freely letting the spring absorb bumps. After 23+years, the stock shackles can freeze up
