what is an air/ water aftercooler?
Prolly a stoopid question, I hear them mentioned ocasionally. Can someone compare all the boost cooling options and maybe even put a couple pics of the air/ water models? Thanx.
Water to air aftercooler for b-series Cummins: It replaces the intake horn and plate. Engine coolant is run through the internal heat exchanger as seen in the pics. The coolant takes heat out of the boosted air and passes it on to the radiator. In hi-perf. applications, some will use a standalone pump and a bucket of icewater instead of engine coolant. These were factory installed where airflow was limited, such as bluebird busses, step vans and offroad equipment. I've also seen them in marine applications, where I hear there's an abundance of cold water If I had to do my intercooler project over, this is what I'd use.
How do these compare to an air-air one though? I don't know how hot the air between the turbo and intake on a non-IC truck gets, but I do know that coolant can get pretty hot. Maybe with a little remote radiator and pump to keep the engine heat away from it...
Also, looks kind of restrictive!
Heh, I read this post not long after watching this video... http://www.youtube.com/watch?v=IotoO153Ir0
Its a 6bta in action....kinda.
Where'd you get all the stuff for that C12h26? I've been planning to do one for awhile but didn't know where to get some of the stuff needed. How did you do your setup?
For a drag, pulling, or dyno truck an air/water cooler will do better than an air to air. For a daily driver or a tow rig you want air to air.
Ok, guys thanks for all the handy info, you learn somethin' new all the time here. Thanks, again, especially for the pics and vids! Cool stuff, no pun intended.
Marcus
12-11-2006 02:00 PM
