What Is Afc Grind
What Is Afc Grind
What is meant by AFC grind??
Well my man from what I know it's the cut on your ve pumps fuel pin. Some guys call it cam pin. Its under afc housing cover hooked the boost diapram you can buy a custom pin or cut your stock pin. Which is what I have done if you need info just holler back. O YEA you will also need to adjust the star wheel all the way down to do any good with this mod. All it dose is make more fuel and boost make sure you have a pyrometer to keep tack off the heat your going to make.
Typically on this website, 'AFC grind' does NOT refer to the fuel pin found under the AFC diaphram atop the pump. What most who mention the AFC grind are refering to is a section of linkage inside the pump top. To access this linkage, the pump top MUST be removed. So, if you haven't removed the top of the pump, you haven't ground the AFC.
the pic is a combined effort of Den and Wannadiesel--thanks fellas!
This mod is permanent- and if you drive hard it will smoke until your turbo is spooled- you can learn to drive clean and still have power. also if you are in a state where you have emmision inspections theis mod will fail.
I love my ground foot.
Michael
Michael
NoSparkplugs
02-07-2006 11:27 AM
