Weekend project
Old 06-30-2005, 12:08 AM
  #46
crobtex's Avatar
Originally posted by Cummins2fast
"I'm hoping for a low to mid 400hp number with these twins."
His nose is getting longer as we speak, 450HP easy.
John
LMAO
Old 06-30-2005, 09:24 AM
  #47
JDGnut's Avatar
He was shooting for those numbers with the HTB2.. might have gotten there with the other pump mods... I know he's shooting for those other 1st Genners with twins... Just going to take some tuning...
Maybe he's just saying.. at 400hp... mine clutch is going to fall apart and I'll get to see how tight the head gasket is glued on...
If he's only going to make 400 with twins.. I should be able to make 600 on my VP with the stock charger....
Bryan
Old 06-30-2005, 10:00 PM
  #48
12vordie's Avatar
NeedMoPower, thanks for the reply, I was thinking of going with an HTT hx35/40 mod kit for the top turbo and an htb2 or 3 on bottom, I wonder if that would work for what I want, good driveability on the daily basis. I would like to know what kind of power I am making now, "would someone like to take a wild guess" if the clutch would hold and then compare it to twin set up after I install it with the head and cam. I am probably going to order a SOUTHBEND clutch next week but don't have any idea which one to get.
Old 07-02-2005, 10:55 AM
  #49
sho_shane's Avatar
Im new at his so I thout I would just ask does anyone make a twin setup for our bikes?
Old 07-03-2005, 10:58 PM
  #50
12vordie's Avatar
NeedMoPower? Did you use aluminum for the piping on the cold air side of the turbos or steel?
Old 07-04-2005, 08:42 AM
  #51
sho_shane's Avatar
Sorry Trucks ( im such a dumb a**)
Old 07-04-2005, 09:02 AM
  #52
swank's Avatar
lots of folks. piers, jr adkins, olee poole, mark kendrick, bd, shied. the list goes on for a while, but i can't remember them all.
Old 07-04-2005, 09:13 PM
  #53
NeedMoPower's Avatar
I made the cold and hot pipe out of 4in. 90's. They were just your standard muffler tubing, but they were also non-galvanized. Also, the 90's were mandrel bends which were alot tighter than most of the ones you find.
The project is 90% complete. All piping is complete and the only thing left to do are the oil feed and return lines. I'm keeping my fingers crossed, but I should be driving it again this week.
Cody
Old 07-05-2005, 08:21 PM
  #54
JDGnut's Avatar
NMP... any work this weekend???
Old 07-05-2005, 09:14 PM
  #55
Everything is finished except for the oil retun lines. John was about to weld up the oil return line, but the regulator on the acetylene bottle broke. He sent it off to get rebuilt today so maybe we can finish Thursday or Friday. I cant wait to drive the truck again!
Old 07-05-2005, 09:49 PM
  #56
JDGnut's Avatar
You're waiting on a regulator.. I got a new set still in the box... Willing to open to see those things spool....
Old 07-06-2005, 04:49 PM
  #57
justinp20012500's Avatar
12vordie,
Running a twin setup using a htb2 on a 2nd gen could be a little difficult, but not out of the question. Alot of people use an ht3b for the bottom turbo. They can be found real cheap (around $500) and are readily available. Alot of your larger 4wd Case and New Holland tractors run an HT3B or an HT60 so that may be another place to look for a turbo, but you'll be hard pressed to find a tractor of that size in the Iola area. I would probably look at an hx40 or something like it for the top turbo though. I'm also not sure if I'd be taking my advice on twins. I have never heard of a person running the twin setup that i'm trying so it may not even work at all. There are many more people who know more about twins than I do.
I'm hoping for a low to mid 400hp number with these twins. My last dyno was 352hp so we will see what happens...
Cody
You can cut a little off the exhaust housing to make it fit.
Cody,
Did you ever pull the gauged plate that covers the dual wastegates? There is alot of improvement to be made there.
Justin
Old 07-06-2005, 11:45 PM
  #58
mhuppertz's Avatar
I think I just wet myself!
Old 07-09-2005, 02:03 PM
  #59
JDGnut's Avatar
Tick-tock.. tick-tock... Where's the twined First Gen... I've been looking out the window all day waiting to see it.... tick-tock... tick tock.... Still waiting.....
Old 07-17-2005, 08:48 PM
  #60
Stomp's Avatar
Yeah whats the skinny? I heard you had it running, but where having some issues. Did you get all of the bugs worked out? DO I need to take mine to the shop so you dont blow my doors off?
Stomp
Quick Reply: Weekend project
