Water temp gauge, fast answer?
Im gonna drop my electric Autometer gauge in in the morning. Will the factory sending unit work with it or do I need to pull it and put the autometer sender in? Fast answer, like I always get, would be really appreciated. Thanks.
Put the new sender in the thermostat housing, There are two plugs you can remove, 1 on the top(may trap air) and reading wont be accurate, and 1 on the side facing alternator(accurate) location, That is where mine is and it works great!
You may need a reducing bushing made of black pipe or brass from home depot,,, I think it is an 1/8 npt X 3/8 npt,,,, or X 1/2 npt, easy job once you get the old plug out!
Peter.
Peter.
However, after looking, I dont see the one facing the alternator. Theres a spot down under the thermostat housing, but it has a line coming out of it. As long as the water level stays full, the top plug should never see air should it?
Put in the top one, that's where I've had mine for a few years. You most likely will have to build a spacer so to speak out of fittings because the aftermarket temp sensor will bottom out in the head.
The one I have is electric, but its Autometer, and Im getting all Isspro white faces, so Im gonna wait and order a mechanical one.
EdmontonCanada
37
12-09-2009 03:18 AM
Racing_Joe66
09-28-2008 09:34 PM
PourinDiesel
06-19-2007 10:56 AM
