Wategate?
Old 08-26-2006, 04:40 PM
whereswaldo250's Avatar
Red face Wategate?
What is the difference between a internal and external wastegate and which one is better? Also is there any diagrams that show how to instal a wategate like one that is on a 12cm housing?
Thanks
Old 08-26-2006, 05:10 PM
An internal wastegate is contained in the turbine housing. It's just a valve that lets exhaust pass from before the turbine into the downpipe. An external wastegate is mounted on the manifold and has a pipe running to the downpipe (or just dumps the exhaust under the hood). An internal wastegate is simple, but they don't flow as much. An external wastegate requires more plumbing, but it can flow more exhaust (not typically important on a diesel).
If you install a 12 or 14 cm wastegated housing and hook the wastegate actuator to a source of boost, you have installed a wastegate.
Old 08-26-2006, 05:56 PM
gman07's Avatar
External wastegates are more common on gassers and twinned CTD's.
I think I understand. What turbos have and internal wastegate? I noticed that you have a 14cm w/g housing how did you plumb the w/g lines?
Thanks I just don't want to screw something up
Old 08-26-2006, 06:03 PM
The HX-35W and and WH1C have internal wastegates from the factory.
I put a tee in the boost port in the head and ran a section of steel brake line under the engine. Short pieces of high pressure fuel hoses go from the tee to the line and from the line to the actuator.
Old 08-26-2006, 07:22 PM
Are there any kits you can buy to hook one up, or is it mainly rigging up your own system? Also when you run a boost guage you can tap it in the same system for your w/g line? I'm new to diesels and I'm still learning?
I hope this isn't too confusing.
Old 08-26-2006, 07:52 PM
shift220's Avatar
Its very easy to rig up your own system with basic parts from hardware stores. Just make sure the tubing can withstand the pressure (stiffer). Yes, a boost guage uses the same line as the wastegate.
Old 08-26-2006, 09:31 PM
Wanna is this what you are talking about?
https://www.dieseltruckresource.com/...cat=500&page=2
Old 08-27-2006, 02:17 AM
Yep. That's my boost port.
Old 08-27-2006, 07:50 PM
So the line in the upper right goes to the actuator and the line going towards the bottom is for what? I know that line sticking out is the end is the boost guage probe. Also how do you get the guage lines through the firewall?
Thanks Ben
Old 08-27-2006, 11:09 PM
flashgordon's Avatar
Thanks Ben
As fare as getting them thru the fire wall i got a 6" pease of a brake or fuel line and cut one end on a 30*eash, angle and push it thru a rubber groment in the fire wall. put the wire's,line or what ever in the metal tube and the remove the tube! wolaa!!!the wires or thru the fire wall.
the fuel line works good for a small wire while the modifyed piece of fuel line work better when you trying to put several wire thru....like when you install a pyro wiring thru the fire wall,..for an example!
Old 08-28-2006, 03:43 PM
Thanks Ben
The line on the uper right goes to the water/meth controller. The line going straight down goes to the wastegate actuator.
Old 08-28-2006, 03:46 PM
Hey thanks that really clarifies things Just for fun why do you run the line under the truck and not over the head??
Thanks
Old 08-28-2006, 03:53 PM
Looks cleaner.
Old 08-28-2006, 03:59 PM
Sweet I know now what to do, I appreciate all the help and dealing with my stupid questions Thanks
Quick Reply: Wategate?
