Wastegate
Wastegate
I have an hx40 with 16cm waste gate housing but the waste gate is just unplugged will it pop open if left not hooked up? Also I am seeing about 20 lbs of boost with it, is there something I can do to get more out of it? I was seeing about 30 out of the h1c with 21cm housing. Any suggestions are appreciated thanx
Are you saying the gate controller is unplugged or the gate is unhooked?
With it unhooked it will allow the exhaust to bypass the turbine and you will have trouble getting any boost.
With a big housing they didn't use a controller or wastegate because there wasn't enough 'motor' to over speed it. So they went to smaller housing to get it spoolled quicker and a gate to control overspeeding it.
Sounds like you're not fueling hard enough to push any more than 20psi, however, check that the spring in the actuator is strong by trying to manually cycle the rod. Without a boost reference to the actuator, drive pressure inside the turbine housing will eventually push the gate open against the spring. Hard to determine what psi that will be though. As was suggested, temporarily hold the gate closed with some mechanics wire and go for a drive.
sallyman1
02-10-2008 06:17 PM
ataboy9026
02-22-2006 05:09 AM
MoparRiggan
10-13-2005 11:54 AM
Copenhagenjunkie
12-27-2002 05:45 PM
