Wanting to upgrad my Turbo
92, w-250 five speed, 4" exhaust, cold air intake, stock injectors. looking to upgrade turbo. i just tow with the truck and plan on keeping stock injector.351cw? hx35? aurora 3000? let me know. dont a shop full of tools so would like to keep it fairly simple. stock turbo is very laggy on bottom end. let me know where i need to go from here.
351cw, its better than the 341cw (03-04.5CR).
Its not a direct bolt on but not alot of work to make it fit either.
If you search 351cw you will find many who have installed one and what is all needed.
Ya they bolt up easy enough but a different intercooler pipe is needed aswell as a flange welded to the dp of the exhaust. The 04 was a split year, early 04 had a 341 and late 04-07 had the 351.
What you need to do is this . Fuel pin ,366 spring ,and a different turbo I went with a hx35 and put a 12 wg housing on it and my crewcab tow's very well .I also have 37's and 410's to give it that extra grunt .but the biggest improvement was when I added a 13 dollar spring to the pump that just makes it rev very easy .
'92 W250 five speed, 4" exhaust, cold air intake, stock injectors. Looking to upgrade turbo. I just tow with the truck and plan on keeping stock injectors. 351cw? HX35? Aurora 3000? ....... Stock turbo is very laggy on bottom end. Let me know where I need to go from here.
Max I have seen so far is 1000 my 12 housing was off of a 95 and it bolted right up to my hx35 that I have no problem with down pipe either I had a 16 and Like it but really enjoy the 12 the WG is closed right now but I will be hooking it up soon .
WEATHERBY460
06-20-2006 08:26 AM
streetsmoker
01-30-2006 01:43 PM
