wanna manual trans.
Auto-to-manual trans. swap?????
HELP!! i gotta 1991 w250 4x4 cumm. auto. and im hopping to stab a G360 in her where can i find a clutch pedal, well i guess the ? is what do i need, the salvage yards within 80 miles of my house are dry what does it all look like?the linkage and lines and ...well differences?????
I just finished this. You need hydraulic clutch lines, master and slave cylinder, tranny, clutch, pedals, flywheel, and a mess of other things...oh and lots of $$$. The lines run from the firewall by the column to the drivers side front of the tranny. No linkages./
Joseph
Nothing just tired of sittin there driving w/o doing anything, its completely stock trans with an added cooler. Ive always owned manual drive trucks and thought this would b better but now i get bored and still hunt 4 a clutch with my foot. so wada ya say?? where do you live?
im not exactly shure ill check in the morn. and get back to ya. but i can tell ya it is a non o/d trans. i'll tell ya what if you are serious about yer swap let me know ill hook ya up!!!
yup i just checked after work it is a 727 i also drained the fluid at the shop and it looked mint. it looks like someone welded a plug into the pan which made it extremely easy. i hate having to drop a full pan. i did drop the pan as well and the valve body looks good. man i wanna shift some gears bad
yeah the pedal rack from any 4sp will work from 72-93. Don't forget teh bracket and hardware!
nope gassers didn't come with g360s as far as I know. And no the auto xfer case won't work, too little splines compared with teh manual xfer case. You'll need a new xfer case!
anyone think they could take an under dash pick for me of clutch assy. how master cyl. hooks up ext.. looks easy enough to make i think "just can't find any parts around here"
I beleive a bearing on the shaft requires that the housing be machined.Someone on one of the 2nd gen forums had a 1st gen 4x parts truck with getrag that he was considering installing in his second gen but that won't work so you might PM him and make a deal for all.
