W350 wheel hop
Old 10-28-2007, 02:41 AM
  #31
dieselcarpenter's Avatar
I had a problem in my old Toyota 4x4 (4" lift 33/12.5 tires) it would hop like crazy in 4lo, had a bunch of guys tell me to get trac bars, and more weight on the tail. If Thumbs doesn't have enough hitch weight could this be adding to his problem? (ie trailer load to far back, all on or rear of the axles?)
PS. 79' -85' solid front axle Toyota's had a torque rod on the front axel to stop axle wrap, problem was when you lift them it changes the geometry, when I got the truck it was lifted and I didn't notice that the rod (hooked to the frame) had ripped a chunk out of the frame, doh! and was now uselessly hanging there. OH WELL, sold it as is, got me a cummins now!!!
Old 10-28-2007, 11:34 AM
  #32
thumbs's Avatar
Oh no Plenty of hitch weight but good thought. I probably have about 7k on the axle.
Old 10-28-2007, 04:15 PM
  #33
SPINPOSI's Avatar
In my Ford I have the same issue, when I back up under load it hops like mad. If I let out on the clutch fast it's fine.
I think... it's a warped pressure plate. Or some would call it a hot spot.
I plan to pull it off and have it resurfaced.
I do have wheel hop from the lift blocks, ford puts 4" lift blocks in the rear to compensate for the D60 front. What a horrible setup.
Old 10-29-2007, 05:02 PM
  #34
dean hinton's Avatar
i have full air ride on my 350 rears i think are 354 no springs at all . i have same problem 80 lbs or 120 lbs still hops on back up.91/5 nv 4500 pac brake 110 fuel in bed streched 50 inches for aero dyne sleeper air lift sys. on rear only pin bottomed out 637350 miles was a former hotshot rig
Old 11-03-2007, 03:45 PM
  #35
james1's Avatar
lift blocks
1. Would a Kelderman setup allow one to "lose the lift blocks"?
2. If one plans to eventually switch to Kelderman, would going with Skyjacker lift springs be a waste of money?
Old 11-03-2007, 09:02 PM
  #36
No, the Keldermann setup is designed to operate at stock height. The bags are at the midrange of their travel when the hanger arms are at the same height as the stock spring hangers. It's not designed to alter the ride height of the truck and will not provide a good ride if the bag pressures are set to change the height. It'll work fine with lift springs like the Skyjackers.
Robert P
20
03-25-2006 02:47 PM
Backwoods
13
02-15-2006 08:00 PM
imdok
06-07-2005 10:13 AM
Tank_66
01-02-2005 07:24 PM
Quick Reply: W350 wheel hop
